Subframe Needs Welding - Need Help!
15 replies to this topic
#1 MiniMaly
MiniMaly
  • 50 posts
Posted 21 February 2013 - 09:14 AM
Can anyone help me or know of a cheap garage that can weld the front of my subframe as it is cracked (I broke really hard and just avoided a 4 car pile up ahead of me and it cracked the subframe) Has a load clunking noise like its hitting together when I drive, sounds really dangerous.
Based near Ealing (Perivale).
Thank you!! :)
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,027 posts
Posted 21 February 2013 - 09:20 AM
Have you got any pictures of the crack?
I think other's on here have said that it's worth getting a new/second hand one, as if it's cracked there before it's likely to crack again if you're in those circumstances again.
#3 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 21 February 2013 - 09:24 AM
I was under the impression that it would fail an mot/illegal if the subframe was welded but I stand corrected if i am wrong.
#4 MiniMaly
MiniMaly
  • 50 posts
Posted 21 February 2013 - 09:33 AM
Oh no :( Well if anyone knows where I can get a whole new subframe fitted then that would be better then! MOT is due in July :(
#5 Mini_Alex
Mini_Alex
  • 175 posts
  • Local Club: East Devon Mini Club
Posted 21 February 2013 - 09:36 AM
It's one of those 50/50 subjects, some people say you can weld them and some say you can't, but you would probably be better off with a new one or refurb a second hand one. (purely for safety)
Edited by Mini_Alex, 21 February 2013 - 09:37 AM.
#6 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 21 February 2013 - 09:44 AM
Have a look in the for sale section on here there have been some for sale in the past. also ebay usually has them as well.
#7 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 21 February 2013 - 10:26 AM
The MOT man welded mine up :o before i bought the car i told the guy i wanted a MOT on it because he said it would easily pass one (not falling for that trick). it failed on the subby and the MOT guy welded it so i presume its not a MOT fail but dont hold me to it. i told the guy i didnt want a welded subby, he knocked more off and i got a 'new' one lol
EDIT - i wouldnt normally want to drive one with a welded subby but at the time i did use that one for a bit. i didnt have the time to swap them over and it never re-cracked and didnt brake if i jacked it up so if its done right it MIGHT be ok. not gunna say its a good idea though
Edited by dennismini93, 21 February 2013 - 10:30 AM.
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 21 February 2013 - 11:05 AM
If welding done correctly why would it fail an MOT...
chassis of a Landrover is basically a great big subframe :) no problems welding those for an MOT
#9 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 21 February 2013 - 11:34 AM
if done correctly it ISNT a fail, so id say to weld it as a temporary solution. I advise you to buy a 2nd hand one and refurb/ fit that very soon.
#10 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 21 February 2013 - 12:05 PM
Ignoring everything else, if braking really hard cracked the subframe then you really, really need to replace it.
The car should be robust to the full power of the engine or brakes - if the subframe cracked just under braking then you've something really scary going on!
Please don't drive the car until you've identified, and fixed the root cause!
#11 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,144 posts
  • Name: Sean
Posted 21 February 2013 - 12:07 PM
It doesn't sound like the sort of thing that i'd be happy welding up on my car. Really the best option would be a new(2nd hand) frame.
#12 Shifty
Shifty
  • 13,144 posts
  • Name: Sean
Posted 21 February 2013 - 12:08 PM
I'm asuming its the front subby we're talking about here?
#13 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 21 February 2013 - 01:07 PM
If its your front subby there's one for sale on here for £30.
#14 MiniMaly
MiniMaly
  • 50 posts
Posted 21 February 2013 - 03:27 PM
Yep it's the front, where would I find that ad? thanks
#15 alex-95
alex-95
  • 6,027 posts
Posted 21 February 2013 - 03:31 PM
http://www.theminifo...46-front-subby/
