Bulb Wattage Question
22 replies to this topic
#16 mini13
mini13
  • 3,810 posts
Posted 22 February 2013 - 10:02 PM
as above....
from someone who has experienced total headlamp faliure at speed from this very instance..... its not fun!
#17 Cooperman
  • 23,295 posts
Posted 22 February 2013 - 10:09 PM
I come from an aircraft and motor-sport background where failure modes are very important. Thus I would never use a single relay for a pair of main beams nor would I ever 'double-connect' the earths. A separate fuse for each bulb filament is also important.
Every circuit should have an independant earth connection. I even fit twin electric fuel pumps, each with a separate power supply from a different power source, separate switches, fuses and earths.
#18 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 23 February 2013 - 12:45 AM
so tell me in black and white, exactly what i should do and from where :P
because im getting a tad confused because theres so opinions on this :P
i trust you cooperman :)
#19 Hegnirst
Hegnirst
  • 3,496 posts
Posted 23 February 2013 - 12:46 AM
thankyou everyone for your input, simply amazed by the response!
#20 tiger99
tiger99
  • 8,584 posts
Posted 23 February 2013 - 12:53 AM
Read carefully what mini13, Cooperman and I said. I don't see any different opinions at all. I happen to be a safety expert in a different field, and am quite appalled by things like single point earths for both lamps.
#21 Hegnirst
Hegnirst
  • 3,496 posts
Posted 23 February 2013 - 12:58 AM
ok then, different way of explaining things, :P because do the wires have to be taken out of the plug that goes into the back of the bulb holder and replaced with thicker wires and completely replaced with thicker ones? or cut back a bit from the bulb holder and put thicker ones in, or with a fuse what combination or which one? :P
thanks
#22 tiger99
tiger99
  • 8,584 posts
Posted 23 February 2013 - 11:31 AM
Yes, you should use thicker wire throughout. You may be able to find bulb holders with thicker wires already fitted. And, as I said, please do ensure that you take the black wire from each headlight directly to its own local earth point, which it can share with the sidelight and indicator on the same side. That will actually need less new wire anyway, so you win on both cost and safety.
#23 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 27 March 2013 - 10:54 AM
can you put http://www.ebay.co.u...=item4d091720a5 these in the headlights or are they no better than the standard H4?? or http://www.ebay.co.u...=item415cf087dd
Edited by dennismini93, 27 March 2013 - 11:18 AM.
