Radius Arm Grease Removal.
28 replies to this topic
#16 MRA
MRA
  • 7,607 posts
Posted 11 March 2013 - 08:34 PM
found one..
http://www.reagent.co.uk/acetone
At £85 per 25L drum plus shipping for a dangerous chemical and VAT on top I guess it isn't cheap is it :-(
#17 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 11 March 2013 - 08:37 PM
I use cutting oil and it costs me £85 per 25L drum :-(
Where would you get Acetone from though ?
That's cheap for cutting oil! MJC are closer to £140 for 25l and that would last me 20 years. I get the acetone from an industrial chemical supplier, you need proof of what it will used for but its not a major problem. Pretty much any local supplier will do it. Prices vary, I think the last lot I got worked out about £1.50 a litre. Paraffin is over £3 a litre where i get it from. I dont use a lot, so would guess you could get it a lot cheaper if you buy in bulk. Panel wipe used to be less than a fiver for 5 litres, aahhhh them were the days.....
#18 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 11 March 2013 - 08:39 PM
I have used CFS, but never for acetone, and they are very good:
http://www.cfsnet.co...cetone_533.html
The 25l is the size I get, so they are a bit more expensive than my local, but they do delivery. The big drum works out very cheap!
Edit: did a quick search and there are loads. These seem pretty cheap:
http://www.ecfibregl...10-acetone.aspx
Edited by Tamworthbay, 11 March 2013 - 08:42 PM.
#19 MRA
MRA
  • 7,607 posts
Posted 11 March 2013 - 08:40 PM
Whats MJC ?
cheap you say, but then again I use nearly 10 at a time.
#20 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 11 March 2013 - 08:45 PM
Whats MJC ?
My brain fade! It's MSC
http://www1.mscdirect.com/cgi/nnsrhm
We get a lot of stuff from them but their prices go up and down very regularly with big discounts for bulk buys which doesn't help us.
#21 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 11 March 2013 - 09:38 PM
Just use brake cleaner in an aerosol can and a tooth brush and give it a good clean out. :thumbsup:
#22 MRA
MRA
  • 7,607 posts
Posted 11 March 2013 - 09:41 PM
That works well if the arm isn't full of grease as is the case in so many radius arms :-(
#23 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 11 March 2013 - 10:05 PM
ultrasonic bath ;-)
#24 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 12 March 2013 - 06:42 PM
hmmm, interesting...
This looks quite interesting (yet very disgusting!) too -
Anyone know how to remove that pin?
Edited by brum,brum,mike, 12 March 2013 - 06:42 PM.
#25 MRA
MRA
  • 7,607 posts
Posted 12 March 2013 - 06:54 PM
Compressed air is potentially very dangerous, even more so with grease added to the equation.
#26 JVA10L
JVA10L
  • 181 posts
Posted 12 March 2013 - 07:46 PM
The pin is a very tight interference fit in the arm and has to be removed with a big press. There is a circlip on the back where the shock absorber pin is so you have to press it out from front to back.
#27 Dan
Dan
    On Sabbatical
  • 21,354 posts
By pin do you mean the stub axle that has been removed in the video? You need a minimum 10 tonne press, preferably a 12 tonne one.
#28 MRA
MRA
  • 7,607 posts
Posted 12 March 2013 - 07:59 PM
I use a 20 tonne press and often, a little extra heat. However I would agree with Dan that a 10 or 12 tonne press would in most cases be sufficient to do the job.
#29 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 13 March 2013 - 09:41 AM
A compressed air grease gun filled with water would push out the grease in that manner a bit more safely and then allow a good run through with Jizer.
I may have just justified a compressed air greae gun to myself...
