Posted 12 March 2013 - 05:31 PM
This is my first Forum post so please be nice haha
I'm thinking of buying a (1997-2000) MPI Mini and I'd like to know if an all new 1380cc engine unit would fit? (without engine-mount modifications and so on...)
I've been looking around for a while and I've only seen SPI's or the old school Coopers (Austin/Morris) with the bigger engines. I'm assuming that nobody has the same intentions as me? haha
The reason why I want an MPI is due to the safety 'equipment' if you can call it that and the big comfy seats...
-Also, with the 1380 engine I'd love a straight cut gearbox.
I just want to know if everything would fit & what sort of performance I could expect?
Thanks for reading,
Matt
Posted 12 March 2013 - 05:54 PM
A 1330 no problem, as long as you stay below 90BHP but a 1380 has significantly more torque and requires a lot more fuel.
Posted 12 March 2013 - 06:02 PM
Posted 12 March 2013 - 06:04 PM
Posted 12 March 2013 - 06:20 PM
if you can afford a whole new 1380 lump, can you also afford a remappable ignition to sort the ecu problem out?
There are no remappable ecu's available at present for MPI's
Posted 12 March 2013 - 06:26 PM
Posted 12 March 2013 - 06:43 PM
Posted 12 March 2013 - 06:51 PM
Seeing that a new engine + gearbox is already a lot of money, perhaps the new ECU's and re-maps are a no-no
In that case, is it possible to run a newer Mini with a 1380 without an ECU?
If not, what about the older MKII/III Coopers? Do they not have one?
Edited by MiniMadMatt93, 12 March 2013 - 07:05 PM.
Posted 12 March 2013 - 07:14 PM
I can't understand why this would be the case ?
Injectors just need a driver module and the ignition just needs a timer module, pretty basically any programmable ECU you work. However the likes of DTA would absolutely work it with no issues,
Posted 12 March 2013 - 07:16 PM
It's been done for SPI's but not MPI's as of yet, perhaps another project for you?
Posted 12 March 2013 - 07:55 PM
You mean a kit isn't available, however it still stands that any decent ECU will make an MPI work just fine.
Posted 12 March 2013 - 09:12 PM
Posted 12 March 2013 - 10:28 PM
Tapping Noise At IdleStarted by Sterling M , Today, 06:50 PM engine |
