Ahh forgot to mention a box of plasters and a tube of germolene. Congrats.
You're not lying...
battle scars.jpg 39.79K
0 downloads
battle scars 2.jpg 42.31K
0 downloads
Posted 05 May 2025 - 06:24 AM
You're not lying...
0 downloads
0 downloads
Posted 05 May 2025 - 07:04 AM
Well, today was the day. I have to say, it went better than expected. Seat out, heater moved to the passenger footwell. I did not need to remove the steering column as I had sufficient room. The old clutch pedal had a 10mm bolt through it, which was easily undone. Getting the pedal out was a bit of a struggle with the spring, a fair bit of brute force. New pedal has been beautifully made by Nippy Cars, with the correct square pedal for older cars.
Fitment into the pedal box was a pain, especially as after struggling to get it all lined up and the pivot bolt pushed through, I found out that if the clutch pedal is held up to the dash, the heel will not pass the bulkhead! So out with the pivot, lower the pedal and redo. Fitting the clevis pin was not too bad, helped by the holding tool. A 'R' clip was fitted in place of the split pin.
I've got plenty of scratches and cuts, mainly from trying to undo the master cylinder bolts on cables and jubilee clips. Pleased it's done, no wear on the pedal now, so the clutch feels better. Thank you for all the advice.
I had am 'R' clip fall out on a drive (luckily the clutch) I'd advise you to fit the split pin.
Posted 05 May 2025 - 07:42 AM
Haynes.jpg 47.18K
0 downloads
Love the Haynes manual (mustard coloured version) description of the task!
Posted 05 May 2025 - 07:43 AM
Fair point - I debated it for a while but was conviced for the clutch. Brakes would be a different matter.
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
