What Grease.
Posted 12 March 2013 - 07:16 PM
Posted 12 March 2013 - 07:18 PM
Wheel bearings and other stuff, Multi-Purpose grease.
Posted 12 March 2013 - 07:24 PM
Posted 12 March 2013 - 07:32 PM
Posted 12 March 2013 - 07:38 PM
Posted 12 March 2013 - 07:40 PM
Posted 12 March 2013 - 07:42 PM
Not sure what is meant by Silicone paste, rubber should be greased with red rubber grease where it is needed (although it's only really needed if rebuilding a brake component, rubber can normally be left alone). Silicone will simply shine it up and won't feed the rubber at all.
The clutch release mechanism should see a graphited grease such as Graphogen.
Copper slip on the BACK of brake pads!
Track rod ends are not serviceable in a Mini, they don't need greasing. All treating the rubber would do is make it shiny.
Edited by Dan, 12 March 2013 - 10:36 PM.
Posted 12 March 2013 - 07:50 PM
Posted 12 March 2013 - 08:24 PM
Posted 12 March 2013 - 08:46 PM
3M Clear Silicone Paste: http://www.amazon.co... silicone paste
And dan, its not for treating rubber parts, its for things like calliper slide pins etc. Where the rubber will be deteriorated by normal MP grease.
Edited by Noah, 12 March 2013 - 08:47 PM.
Posted 12 March 2013 - 09:17 PM
Ah yes, and copper grease on brake pads to stop squealing
This is very dangerous !
You can apply copper slip, however please make sure NONE of it goes near the friction surfaces of the pad and or disc !
Posted 12 March 2013 - 09:38 PM
lol, i remember reading an article about a woman that crashed her car when she sprayed all inside her wheels with wd40 to stop brake squeal !!
i call it natural selection... but id rather not see any minis hurt in the making.
Posted 12 March 2013 - 09:55 PM
Posted 12 March 2013 - 10:04 PM
Posted 12 March 2013 - 10:27 PM
In a Mini? There isn't anything needs to be greased like that in our cars, they were designed in a time when lithium grease was fairly modern.
Edited by Dan, 12 March 2013 - 10:31 PM.
