Mini pickup rollcage
Posted 06 June 2004 - 05:17 PM
Posted 06 June 2004 - 06:06 PM
one word of warning though, the arent cheap, i asked about a price for a cage for my jem, and they said as its a one off, the price would start at £2500!!!!
Posted 06 June 2004 - 06:11 PM
Posted 06 June 2004 - 06:15 PM
Posted 06 June 2004 - 07:10 PM
bluemini(red): Nice pickup, i like the rear role bars but im hoping to get a tilt for mine so i want a cage for inside. Im sure someone must have done it at one stage as i think pickups have been grasstrcked in the past.
Ive had a look at your new site too, nice stuff (mini and site!). Just wondered how difficult it is to modify the calipers to fit over wellers like that? I have a set of wellers that i want to put on the pickup and an 8.4" setup of my mates crashed mini so before i fork out for an S setup id like to see it i could do it.
thanks
Posted 06 June 2004 - 07:51 PM
As for the calipers, its tial and error, but dont do it if your not confident. If you do try it, I recomend you seperate the two halves of the caliper and have a look were the fluid galleries are so you dont break thru into them.
Posted 07 June 2004 - 11:43 AM
Im fairly confident in the garage so ill give it a go. The breaks need a rebuild before i put them on so ill see inside when im doing that. What did you use to do the machineing, a dremal with a grinding attatchment?
Posted 07 June 2004 - 05:22 PM
A grinder! :gasp: :grin:
Just do it a bit at a time and keep fitting the wheel to see if it rubs. You'll need to bolt the wheel up tight to make sure it clears ok, as holding it in place isn't good enuf.
As for the cage, make some brackets yourself.
Posted 07 June 2004 - 06:59 PM
i take it you mean deans mini's, have you had much to do with him?.....he any good?bluebottle: Soham isnt far at all and thats where my local mini garage is too ill have to give them a call cheers.
Posted 07 June 2004 - 07:54 PM
Posted 07 June 2004 - 07:57 PM
yeh bluebottle ive had a few dealings with deans through my mate, who had a load of work done there. They did an ok job and replaced rusty pannels rather than plating overthem but it wasnt the best job and we've since gone over some of the work they did to tidy it up. It did get through the mot though. Was abit steap to, at £200 for each sill but at least they didnt do an oversill.
Posted 07 June 2004 - 08:43 PM
i think he gets used to ripping off the yanks from the local airbases, and keeps the silly prices for everyone else as well!....luckily my car never needs welding!
Posted 07 June 2004 - 10:40 PM
Never needs welding! You do have a mini dont you?!yeah, i'd heard mixed things about him, and he does seem to be rather dear!
Posted 08 June 2004 - 05:26 PM
Posted 08 June 2004 - 06:06 PM
