Any ideas guys?
Edited by ashc94, 19 March 2013 - 02:04 PM.
Posted 19 March 2013 - 02:03 PM
Posted 19 March 2013 - 02:34 PM
Posted 19 March 2013 - 02:44 PM
I was just wondering would bad spark plugs/leads contribute to the engine loss of power?So basically among other problems which have been resolved, in a morning in whatever weather my car finds it difficult to warm up and ends in cutting out half way down the road. I have tried warming up for a longer period of time and I have been told to check the heater temp. for an indication (no temp. gauge is installed). On top of this whether this is related or not when sat still in neutral the engine seems to dip in power every few seconds which I thought was unusual.
Any ideas guys?
Ill have a look into that, thanks for the suggestionSo basically among other problems which have been resolved, in a morning in whatever weather my car finds it difficult to warm up and ends in cutting out half way down the road. I have tried warming up for a longer period of time and I have been told to check the heater temp. for an indication (no temp. gauge is installed). On top of this whether this is related or not when sat still in neutral the engine seems to dip in power every few seconds which I thought was unusual.
Any ideas guys?
Posted 19 March 2013 - 02:54 PM
Posted 19 March 2013 - 03:01 PM
Yes warm air comes out of the heater I had been told to use that as an indication of the car temp. but the car still stops. I might just change the spark plugs and leads and see if it ticks over more consistently. We have recently changed the head gasket and set the points so I don't think they will be an issue. Thanks for the help.Does hot air come out of the heater then or not? If it doesn't then perhaps you are running low on coolant (or the valve to the heater circuit has failed).
Uneven idle could be a number of things but is often down to ignition timing being out, or a misfire indicating another problem with ignition components e.g. spark plugs, points etc. It may need a service. I would have thought this would be the reason the car is stalling, more than anything to do with temperature as unless the car overheats (and you have the opposite problem) I don't think running a little cold would cause it to stall when being driven.
Edited by ashc94, 19 March 2013 - 03:02 PM.
Posted 19 March 2013 - 03:05 PM
Edited by lewBlew, 19 March 2013 - 03:06 PM.
Posted 19 March 2013 - 03:12 PM
Yeah the engine does not like choke at all so it has to be warmed up properly. I will have someone look at the tickover/mixture screws to see if it solves this problem.Yes and get the timing checked with a strobe if you have a friend or friendly garage near you. That might help the running.
Another thing is, is the choke in good order and working properly? If the car is cold and you drive off without enough choke you would stall.
Posted 19 March 2013 - 03:42 PM
Posted 19 March 2013 - 03:44 PM
Yeah I agree it doesn't agree with more than 1/8th choke so its hard to warm up moving. :/ thanks for the helpWarming the car up properly is driving it! It's very bad for it to sit and warm up at idle, it warms up far quicker being driven anyway. To be honest it just sounds like it needs a good service and tune up.
Posted 19 March 2013 - 04:00 PM
Posted 19 March 2013 - 04:49 PM
Fingers crossed.You might need the carb/choke setting up properly then? It should run lovely with the choke out
Posted 19 March 2013 - 06:30 PM
Eventually solved this problem. worked out it was tickover and mixture problem thanks for the help anyway guysSo basically among other problems which have been resolved, in a morning in whatever weather my car finds it difficult to warm up and ends in cutting out half way down the road. I have tried warming up for a longer period of time and I have been told to check the heater temp. for an indication (no temp. gauge is installed). On top of this whether this is related or not when sat still in neutral the engine seems to dip in power every few seconds which I thought was unusual.
Any ideas guys?
Posted 19 March 2013 - 06:50 PM
Posted 20 March 2013 - 12:07 AM
