Help Please Oil Pressure Light Glowing
39 replies to this topic
#31 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 April 2013 - 04:58 PM
PSI =Pounds Square Inch, so 20PSI
#32 se_juggles
se_juggles
  • 1,043 posts
Posted 08 April 2013 - 05:07 PM
mine where always on with my last one. got it checked and they couldnt find the problem I knew something was wrong when they went out.... the light bulb had gone...........
#33 CantBeat@Classic
CantBeat@Classic
  • 31 posts
Posted 08 April 2013 - 05:35 PM
Cant Be
http://wiki.answers....vert_lbs_to_psi
You can't convert pounds to pounds per square inch (psi). One is force and one is pressure. If you know the area over which the force is spread, then you can divide the force by the area and get pounds per square inch (psi).
so it cant be 20psi
#34 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 April 2013 - 06:42 PM
Yes it is. There is no conversion involved, they have just written pounds as a short form of pounds per square inch.
#35 CantBeat@Classic
CantBeat@Classic
  • 31 posts
Posted 08 April 2013 - 06:50 PM
oh last time i use wiki thanks for clearing that up
#36 tiger99
tiger99
  • 8,584 posts
Posted 09 April 2013 - 10:23 PM
If Wikipedia is wrong, why don't you correct it? I usually do when I see an annoying error.
#37 CantBeat@Classic
CantBeat@Classic
  • 31 posts
Posted 15 April 2013 - 05:46 PM
Because id rather know what im talking about before sharing
#38 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 April 2013 - 05:52 PM
Its just a slip up on the site saying its a 20lb switch rather than saying its a uprated 20psi switch. and its always good to be sure of your facts as you put @clasics
#39 CantBeat@Classic
CantBeat@Classic
  • 31 posts
Posted 16 April 2013 - 06:49 AM
I used the @ as "a" rather than "at" its just by look not real use
#40 iwatkins
iwatkins
  • 381 posts
Posted 16 April 2013 - 07:40 AM
I was going to get one of these, but didn't fancy adding another 20lbs (9.07kg) of weight to the car ;D
