skimming heads
Posted 17 April 2006 - 07:12 PM
Posted 17 April 2006 - 07:33 PM
heya, got a 998 cooper 12g295 cylinder head that i want to put on my 998 mini. The block and pistons are all totally standard. Vizard says that before putting this head on the block i need to have it skimmed to raise the compression ratio to a minimum of 9:1.
Yes - the 998 cooper engines used pistons with a raised D shape in the piston crown...
Depending on your 998 engine, you will have either flat top or dished pistons..
Its *roughly* 60 thou, assuming the cooper head you have is at standard. Reshaping the chambers will effect it.Does anyone know how much i need to have off? If i get the chambers reshaped will i need to have the head skimmed again to change the CR once more?
You need to work out the CR properly, and measure the chamber volumes of the cooper head accordingly..
Be carefull that skimming a wedge of the head can lead to other problems, both with the head, valve train geometry, etc :\
Not much - trick is finding the correct springs for the cam and intended RPM - too heavy (single or double) and it'll cause more harm than good...One other thing, what are the benifits of double valve springs? Am i right in thinking they wouldn't be much use on a very mild road 998?
HTH,
Dave
Posted 17 April 2006 - 07:55 PM
In addition to the information above, and since you have a copy of Vizard, I recommend that you start by looking closely at what you have and what you want to do. Don't shave the head until you can tell the machine shop exactly how much you want off of it.
Before anything else you need to CC the chambers to determine their volumes. While you're measuring, be sure to carefully measure your bore and stroke. If the pistons are dished, you'll need to CC the volume of the dish. Measure the head gasket thickness and it's bore. Don't forget to measure the distance from the top of the piston down to the first ring AND the OD of the piston. It all adds up and there is no substitute for measuring twice and cutting once.
I found a fair amount of difference between the chamber volumes on my 12G940 head. I suggest you study Vizard on measuring chamber volume, correct and balance the volumes as necessary, then calculate the remaining volume you NEED to get the CR you want. You'll have to do some creative math to figure out how much AREA the chamber has, and from there determine how much to shave off the head. Anything less is just a guess.
Posted 17 April 2006 - 08:00 PM
Posted 18 April 2006 - 12:17 PM
That brings up a useless bit of trivia. At the turn of the last century the world was starting to make and use electric light bulbs and Thomas Edison was growing the R&D division of Edison Electric. They were starting to fill bulbs with inert gasses instead of vacuum. One group was assigned the task of calculating the volume inside a typical bulb. After working on the problem for weeks a young mathematician came up with the formula and very excitedly reported his results which were soon forwarded to Edison. Edison went to see the young man and thanked him for his efforts. He then said to the young man, let me show you how I find the volume of a bulb. He went to a sink where he filled an empty bulb with water. He then emptied the bulb into a graduated cylinder, read the volume in cc, and walked out of the room. Sometimes the obvious is right before our eyes and we don't see it.
Thanks again Dan.
Posted 18 April 2006 - 12:39 PM
Posted 18 April 2006 - 01:20 PM
Posted 18 April 2006 - 02:36 PM
Incidentally dan, approx how much can you skim off safely before breaking into something that you shouldn't?
Posted 18 April 2006 - 02:48 PM
Posted 18 April 2006 - 05:46 PM
Posted 18 April 2006 - 06:00 PM
Posted 18 April 2006 - 08:52 PM
