Temporary Rust Repair
rust repair
7 replies to this topic
#1 welshy
welshy
  • 105 posts
Posted 24 March 2013 - 10:54 PM
My mini shell was severely hosed down by the fire brigade when my neighbours Beko dryer caught fire (if you have Beko products, check the model number on line).
My shell was mostly painted (old paint) but had quite a bit of bare metal due to several panels being replaced. My mini now has quite a bit of surface rust. I am after a quick way of killing the rust and also want to prevent future rust. This will only be temporary (6-12 months) as the shell will eventually be fully stripped, primed and painted.
What would be the best product?
Sorry if this has been asked before, but searching mini and rust produces a lot of results, most of which are for clean painted metal.
Ben
Edited by welshy, 24 March 2013 - 11:03 PM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,073 posts
  • Name: Neil
Posted 24 March 2013 - 11:02 PM
You will need to rub the rust back to bare metal then treat it with something like Krust. Once that's done it will need a flash of topcoat.
#3 welshy
welshy
  • 105 posts
Posted 24 March 2013 - 11:06 PM
Hi,
Hanks for he reply.
Rubbing it all back will take quite a while, I was hoping for something I could quickly brush on. I have a tin of wax oil which according to the tin would work, but it will be messy to remove.
Ben
#4 joakwin
joakwin
  • 958 posts
Posted 25 March 2013 - 05:56 AM
sand it down is the right way to do it
#5 corrado vr6
corrado vr6
  • 678 posts
Posted 25 March 2013 - 01:28 PM
Yep wire wheels and flap discs is the best way then treating, wax oil will just trap the rust in and allow it to grow under the wax oil.
After treatment topcoat as suggested not just primer as that will still allow moisture in
#6 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 26 March 2013 - 09:04 PM
How about phosphoric acid?? Brush some on, leave it overnight and it will seal the metal up from rust. It can be wire brushed and painted when its dry.
#7 jaydee
jaydee
  • 8,565 posts
Posted 27 March 2013 - 10:38 AM
Phosphoric acid is the faster and still good but you need to sand it down
#8 Minidarren83
Minidarren83
  • 1,207 posts
Posted 27 March 2013 - 11:21 AM
Check out www.rust.co.uk a quick rub down and full coat of epoxy mastic 121 you can then leave the car for as long as you want with no rusting and the surface prep is minimal
Darren
Also tagged with one or more of these keywords: rust repair
