im converting front drums to discs... will i need new drive shafts? ta
drums to discs conversion
supermotolee
, Apr 18 2006 05:27 PM
8 replies to this topic
Posted 18 April 2006 - 05:27 PM
Posted 18 April 2006 - 05:29 PM
i dont think u do but if u can id suggest using a new driveshaft circlip as its possible for the shaft to pop out with a worn clip.
Posted 18 April 2006 - 05:49 PM
I did the conversion at the weekend, yes I used the driveshafts from the 8.4 setup, but kept the pot joints from the drum setup to avoid draining the oil.
Posted 18 April 2006 - 06:49 PM
I changed from drums to discs and used the existing driveshafts.
Posted 18 April 2006 - 09:06 PM
right worked it out its not the actual driveshafts its the bits that go into the hub itself that are different so not to worry panic over...
Posted 18 April 2006 - 09:10 PM
This will come in useful in the next few weeks.
Would make a good sticky in F&Qs!
Posted 18 April 2006 - 09:13 PM
will definately come in usefull, im doing mine in a few weeks too!!
Posted 18 April 2006 - 09:18 PM
i have mrs bungles to change as well
Posted 18 April 2006 - 09:30 PM
the big bits that go in the hub are called Cv's aren't they?
