Posted 07 June 2004 - 04:51 PM
caps are used to suplement the battery....and go by the amps.....so say i have a 500 watt rms amp i would need a 1/2, but for a 1000 watt rms a 1 farad.....but like alburglar said, you shouldnt need a cap unless your volts is dropping...a good amount....and if it drops below somewhere around 6-8 you should invest in a second battery....or a better altanator....(sorry if stuff is spelled wrong.....i just got off a 11 hour shift)
