check the fuse's first, like said if you have glass fuses then check them yo see if the thin wire in the middle is in one piece, the ones in the box in the engine bay will easily twist round so you can check. next would be to check for the ones in a plastic tube about 4-5cm long, these simply twist apart to allow access to the fuse, they also corrode on the ends so check check that as well ( scrape will a small screwdriver to get a contact surface)
another thing to look out for are blade fuses, I suspect a few of our minis have been modified for the use of blade fuses, these are a bit harder to see but in the middle of the plastic part will be a zig zag peice of metal, check to see if its in one one piece.
There are hidden fuses behind the dash and and steering column. check the fuses and if one has gone then we can can point you in the right direction to solve the problem :)
you are a genius! I wish I actually properly read the bit that told me to look behind the steering column! it was you that made me recognise the plastic tube one or i wouldnt have looked twice at it!
xxxxxx
