Help With Roof
Posted 03 April 2013 - 08:21 PM
Posted 03 April 2013 - 08:22 PM
The paint there is incredibly thin.
Edited by Noah, 03 April 2013 - 08:23 PM.
Posted 03 April 2013 - 08:26 PM
take it back for a winge as that shouldnt happen so early on!
you can also tell they didnt sand it down, was it a bargain price?
the labour to prep well is astronomical
Edited by mini*mad, 03 April 2013 - 08:27 PM.
Posted 03 April 2013 - 08:31 PM
Posted 03 April 2013 - 08:32 PM
Posted 03 April 2013 - 08:38 PM
it isnt thin, it was just incorrectly prepared & the primer they used is wrong
You can see they have done one quick blow over the primer, you can see the layers. And that is the gutter, where it would be thinnest, I bet if you put a paint depth gauge on the roof, it would be 70microns and lower.
Edited by Noah, 03 April 2013 - 08:39 PM.
Posted 03 April 2013 - 08:44 PM
if it was done correctly and prepped correctly then it would stick to the metal
but i do forget at 16 you do know everything
Posted 03 April 2013 - 08:51 PM
should have been sanded, high build etch primer, sanded, couple of colour coats sanded, lacquer, sand etc.
Technically as its rusty really if you were doing it properly then you would be replacing metal then etch primed, high build etc etc ;)
Posted 03 April 2013 - 08:54 PM
but a year ago it probably was bare metal,
i'd see what it was like after a good seeing to with 80 grit
but defo take it back and complain nicely, pretty easy cost effective job to remedy so im sure they wont mind :)
No need to be sarcy now. He doesn't claim to know everything.
Back to the problem in hand. Take it back to the restorer definitely.
Posted 03 April 2013 - 08:59 PM
Posted 03 April 2013 - 09:03 PM
Just seen that thanksMoved to bodywork section too. Might get a better response in here.
Posted 03 April 2013 - 09:12 PM
