Steering & Handling Problems...
Best Answer tiger99 , 07 April 2013 - 02:14 PM
Whatever you do next, do not drive the car with an overheating bearing. It will fail, and most probably spectacularly.
I don't know if you used genuine Timken bearings. SKF are also good, if you can get them in the size, but beware of anything else, which is mostly dangerously defective Chinese junk, as we keep seeing on this forum. It is a waste of time and money to use non-genuine bearings, as well as often being dangerous. Yes, I do know that genuine Timkens are expensive, but what is your time and trouble, or your life worth?
Now for the cause of the overheating. You will have fitted the bearings carefully, and greased them properly, so we need to consider that the most likely thing is that the preload is wrong. Actually, if taper rollers, there should be no preload, only slight end float, but a minimal amount of preload is normal on ball bearings. Minis could be using either type.
Excessive preload means that the bearing spacer is incorrect or missing, the outer races are not seated correctly in the hub (e.g. due to dirt), or the bearings have been machined wrongly, which sadly is the most likely these days. Not all bearings have a spacer, on some the inner races protrude to give the same effect, but in every case the complete bearing set must be used together, as they are machined individually. So, you can't use the old spacer with new bearings, or mix a pair of spacerless bearings with another pair.
Please check the stub axle for signs of severe overheating (blue colour) when you strip the bearing, which you inevitably will have to do. If the axle has been overheated, please change it for safety's sake.
Oh, and if you can establish that you have done nothing wrong, take the bearings back to the supplier and demand at least your money back. In my opinion you are entitled to compensation for wasted time too, but I am not a lawyer. If they refuse to give you a refund, just mention Trading Standards. They can get into all sorts of very serious trouble for supplying dangerously defective goods.
Go to the full post
Posted 06 April 2013 - 11:47 AM
Sorry it's such a long one but im at my wits end and can't think of any other causes. Anyone have any ideas or had a similar experience?
Posted 06 April 2013 - 11:58 AM
Posted 06 April 2013 - 12:00 PM
Posted 06 April 2013 - 12:16 PM
How do I check for cv joint play?
The steering rack noise sounds like taking a tescos trolley over a cobbled road, but not quite as loud. Should there be any noise at all?
And yes, no animals in the wheel arch ;)
Thanks for your help guys
Posted 06 April 2013 - 12:18 PM
Posted 06 April 2013 - 02:16 PM
Posted 06 April 2013 - 02:36 PM
Posted 06 April 2013 - 02:48 PM
Well the handbrake barley works as it is.. It won't even hold the car on the slightest gradient so I guess that rules that out? They were sold to me as two reconditioned radius arms from a UK company through eBay. There isn't really any play I can feel with both wheels off the ground and shaken at 3 and 9 and 12 and 6 so I think they are okay. How could I physically check that they are not faulty?
Take the pin out and look to see what the bearing, bush and pin are like. Its worth checking just to be able to rule this out. What is the subframe like?? is it in good condition and all of the mounting bolts fitted??
Check the rear wheel bearings, take them out inspect them and if ok repack with grease and reinstall.
Is the car sitting level at the back ?? Have you got Hi Lo's fitted if so strip out the hi lo the cone and ball end. Check to see if the nylon / plastic cup is installed / damaged.
It really is a case of going through all of the suspension components bit by bit part by part.
I think as mentioned check the quadrants to ensure they are free to move. Then the drums themselves ensure the handbrake arm is free to move, take the drum off and check to make the adjusters work correctly. Strip them out clean them up and rebuild with a dab of copper grease.
Its worth looking at the slave cylinders as well. make sure they move freely.
Posted 07 April 2013 - 11:47 AM
Posted 07 April 2013 - 02:14 PM Best Answer
Posted 07 April 2013 - 02:52 PM
Edited by Dan, 07 April 2013 - 02:54 PM.
Posted 08 April 2013 - 11:08 AM
Posted 08 April 2013 - 11:27 AM
Although not on a mini i had a front wheel bearing fail big style on my RS2000 whilst in the outside lane on the A1M at over 70 mph. Severe brown pants moment and very fortunate not to have a major accident. Believe me it really is not worth your life or others over a relatively cheap and easy item to install / replace.
Posted 08 April 2013 - 12:33 PM
Posted 08 April 2013 - 02:11 PM
