Hi, have just fitted some adjustable radius arm brackets and I am unable to find the settings in my trusty old Haynes manual.I did have a look, in the torque setting section but was unable to see it. In my Haynes manual all it has is the pivot shaft nut @53 lbs. Also how tight would you go on the sub frame mounting bolts ?
4 replies to this topic
Posted 07 April 2013 - 10:13 AM
Posted 07 April 2013 - 10:47 AM
If there is no published torque wrench settings the the following is a good guide
1/4 UNC/UNF 7 ftlb
5/16 UNC/UNF 18 ftlb
3/8 UNC/UNF 30 ftlb
7/16 UNC/UNF 55 ftlb
1/2 UNC/UNF 66 ftlb
5/8 UNC/UNF 100 ftlb
and that's the thread size and not the size of the spanner you use
1/4 UNC/UNF 7 ftlb
3/8 UNC/UNF 30 ftlb
1/2 UNC/UNF 66 ftlb
Posted 07 April 2013 - 10:53 AM
Thanks for that, no reason not to do it now. off I go
maybe one more coffee
Posted 07 April 2013 - 02:18 PM
The old BL manual confirms that with 18 lb ft, and the new Rover manual with 25 Nm, which is almost exactly the same. It is a strange omission from Haynes.
By the way, that same torque figure is suitable for all 5/16" UNF nuts or bolts anywhere on the car unless otherwise stated. There are other figures for the UNC threads which screw into soft alloy in the transmission.
Posted 17 April 2013 - 01:43 AM
I set mine at 20 lb ft from an old bmc book I found
Also tagged with one or more of these keywords: suspension
