Low Oil Pressure And Low Rev's / Stalling Issue
17 replies to this topic
#16 BigKevG
BigKevG
  • 21 posts
  • Local Club: Nuts About Mini's
Posted 19 April 2013 - 07:07 AM
Cheers for the replies chaps! Learnt a lot from the above. The car seemed fine last night and this morning, reading the following:-
Cold running at 30mph - 60/70psi
Cold idling in traffic/lights etc - 60/65psi
Warm running at 30mph - 60psi
Warm running at 40/45ish-mph - 40psi
Warm idling in traffic/lights etc - between 30/40psi
I'm not sure, but that seems about right to me, so maybe it was just a one off incident.
Thanks for the advice guys, I will take it all in.
#17 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 19 April 2013 - 09:28 AM
Figures could be higher, but for what I assume is an aging engine, it sounds alright.
If you change the oil and filter, make sure to prime the new filter before fitting!
#18 Cooperman
  • 23,370 posts
Posted 19 April 2013 - 09:39 AM
As 'Golfclubby' says, that all sounds fine. Maybe you got a bit of muck in the carb which slowed the tickover with a resultant low oil press reading as a result, quite simply, of the oil pump going round more slowly.
It would be a good idea to change the oil and put a top quality 20w50 in together with a new oil filter.
Re-set the tickover, if necessary, to about 800 to 900 rpm with engine warm.
