Positive Camber But From Where?
18 replies to this topic
#16 mars red mike
mars red mike
  • 1,500 posts
Posted 23 April 2013 - 06:52 PM
No the tracking was done on the floor with a Gunson TrakRite. The car never actually left the ground. Thanks for the suggestion though
#17 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 23 April 2013 - 07:35 PM
No probs!
#18 TMW.Racing
TMW.Racing
  • 248 posts
Posted 15 September 2014 - 11:39 AM
Sorry to resurrect quite an old thread but I have exactly the same problem - did you ever get to the bottom of it?!
Anyone else got any other ideas?
#19 Cooperman
  • 23,355 posts
Posted 15 September 2014 - 03:16 PM
The only thing that can alter the camber is the effective length of the bottom arm. Everything else is fixed length.
So one must ask what can do that. The only answer is the lower arm bushes.
Measure what you have in terms of actual camber by using a rectangular piece of plywood against the tyre with the car sitting normally. Measure from the edge of the ply to the lowest point on the wheel rim and the highest point and compare these two dimensions. By using a simple calculation you can determine the camber angle, positive or negative.
Mini Spares sell some offset lower arm bushes which can be used to correct minor errors and differences.
