Hello
Can someone please help me.........
I need to know where in the gearbox the LAY GEAR IS as i have just split the engine & gearbox and i have been told that under the LAY GEAR there is a bush which i need to tap back in and i am unsure where the LAY GEAR IS please please can somebody help me...
Wayne.
i need help please !!!!1
Union-Jack
, Apr 23 2006 05:34 PM
4 replies to this topic
Posted 23 April 2006 - 05:34 PM
Posted 23 April 2006 - 05:59 PM
I ALSO THINK IT COULD BE CALLED THE PICK UP GEAR ????????????
Posted 23 April 2006 - 08:46 PM
laygear is the one with the 4 teeth gears all machined on one shaft so did u win that mini on ebay from a chap in redhill?
dave
dave
Posted 23 April 2006 - 08:56 PM
dave
hi dave
yes i got it from the bloke in redhill ...
do you know if there is a bush behind it or under it or anywhere around that may need knocking in, also i am not very good with engine / gearboxes so it the one in question the top middle or bottom set.
thanks dave this is very good of you ............
wayne.
Posted 23 April 2006 - 09:04 PM
dave
hi dave
wayne.
yes there is a busy under it all, and if you want some advice, get the gearbox sorted with a proper rebuilt item, as you dont want to have to take it apart again and again
dave
