Reversing Light Stays On?
Posted 29 April 2013 - 11:34 AM
But I was wandering what you guys make of this.
As I left for college (reversed out of the drive) and pulled away my dad text me to say that my reverse lights stayed on down the road. When arriving at college, I left the ignition on and had a look round, it wasn't on. I had no funny looks while sat in traffic on my journey either.
I went to move the car last night, and whenever headlights are on, so are the reversing lights. Confused?!
It is a 84 city e and other that playing around with carpet/underlay. I haven't touched anything. Could I have knocked the reverse light switch? Or just a dodgy earth somewhere? Any help appreciated..
Jack
Posted 29 April 2013 - 11:57 AM
I would guess at an earthing problem in the boot. Check and clean up all the rear light connections.
Posted 29 April 2013 - 01:27 PM
The wiring for the reverse light does go under the carpet , so if you were messing with that like you say, I'd peel it back and check the wiring .
Posted 29 April 2013 - 02:18 PM
Very possibly a stuck switch. They're a ******* to get to without a lift, but it's doable. The switch screws into the side of the selector box.
While you're there, check the cables too, as they go brittle and can short out because of the heat of the exhaust.
Posted 29 April 2013 - 02:29 PM
Make sure the switch in the selector box isn't screwed in too far.
Posted 29 April 2013 - 02:53 PM
Posted 29 April 2013 - 05:48 PM
As soon as lights are switched on, reversing lamps are illuminated. No matter what gear is selected.
I'm more inclined to say its an earth fault now? Any helpers?
Posted 29 April 2013 - 06:08 PM
Sure is a earth fault by the looks of it check the wiring and connections as the side lights are finding a earth through the reverse lights
Posted 29 April 2013 - 10:03 PM
does sound like a earth problem
Posted 30 April 2013 - 08:18 PM
Between us, we have cleaned up the earths for the rear loom, removed and cleaned all bulbs, checked fuses and selector switch connections.
I have resulted to removing the reverse lights bulbs so that i can drive the car.
Where do I look next?
Posted 30 April 2013 - 08:20 PM
Posted 30 April 2013 - 08:47 PM
Green/brown is the wiring to the reverse lights from the switch.
Unplug the wiring in the boot and see when the green/brown goes live...If it goes live when the lights are on it suggests a short in the loom.
Posted 01 May 2013 - 06:09 AM
Have you changed ANYTHING before the problem started?
Not as far as I am aware.
Posted 01 May 2013 - 06:37 AM
In that case im with lrostoke on this one: grab a multimeter and start measuring:)
Posted 01 May 2013 - 07:42 AM
