Oil Leak From Back Of Distributor
29 replies to this topic
#16 marsy
marsy
  • 374 posts
Posted 29 April 2013 - 08:39 PM
65DM4 has a external module on the outside and would be a O.E distributor for electronic ignition
Sorry to sound like a plank! But what does O.E stand for? Or what does it mean? :s sorry
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 April 2013 - 08:44 PM
O.E =Original Equipment, sorry in the car trade we just describe factory fitted as O.E Parts
#18 marsy
marsy
  • 374 posts
Posted 29 April 2013 - 08:54 PM
Ahh thankyou! Will spilt the distributor down tomorrow and see what I find!
#19 marsy
marsy
  • 374 posts
Posted 30 April 2013 - 09:08 AM
I have split the distributor down, and all seems ok. So what next?:( put back together put on car and check crankcase pressure???
#20 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 April 2013 - 01:06 PM
So is there wear in the bushes ? and movement to and fro?
#21 marsy
marsy
  • 374 posts
Posted 30 April 2013 - 01:17 PM
In the bushes? Sorry where are they? Looking at exploded diagram and cant see them? There is a very small amount of movement at the bottom of shaft where the thrustwasher is, but not sure how I can stop that, to be honest??
#22 marsy
marsy
  • 374 posts
Posted 30 April 2013 - 01:18 PM
The thrust washer that is at the end with the drive dog
#23 Ethel
  • 26,025 posts
Posted 30 April 2013 - 01:32 PM
It is supposed to pass some oil to lube the dizzy spindle. As above, if you're getting too much you either have too much crankcase pressure or the bush is worn or a bit of both. Sideways movement of the shaft would be an indicator of wear.
#24 marsy
marsy
  • 374 posts
Posted 30 April 2013 - 01:36 PM
No side ways movement, I very small bit up and down, what would the to much crank case pressure indicate a problem with??
#25 marsy
marsy
  • 374 posts
Posted 30 April 2013 - 02:10 PM
No side ways movement, I very small bit up and dwn, what would the to much crank case pressure indicate a problem with??
There is actually a small amount of movement on the shaft on the bottom bush, where can i get a replacement bush from?
Seems there is no where that does parts, only the whole unit, thanks
#26 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 April 2013 - 02:14 PM
Job to get bits you could try the distributor doctor http://www.distributordoctor.com/
#27 marsy
marsy
  • 374 posts
Posted 30 April 2013 - 02:40 PM
that Job to get bits you could try the distributor doctor http://www.distributordoctor.com/
Thanks have tried him and not got anything that new,
What would be a direct replacement, distributor and coil, for a 1275? Thanks
#28 G4RZZ
G4RZZ
  • 61 posts
Posted 01 May 2013 - 09:50 PM
Don't mean to but in but I have the same engine and the same problem,oil travels up the hole before the O ring and spills out the casing.I have asked a few people and was told its down to a crankcase pressure problem or a worn engine possible rings etc also to do a leak down test.but as a quick fix NOTa cure is to plug the hole before the O ring with some sealant.
#29 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 May 2013 - 10:00 PM
If you plug the hole in the Distributor with sealant the excess oil will build up inside the distributor and get thrown about by the advance weights and come up through the baseplate causing problems with the points or the hall effect electronics and getting inside the cap and cause misfiring and bad running or even cut out.
The fix is either see if you have wear in the distributor shaft bearings or excess crankcase pressure and I would be running the crankcase breather connnected to the inlet which would cause a vacuum in the crankcase. Obviously if your engine is worn then a overhaul would be in order to rectify the problem.
#30 tiger99
tiger99
  • 8,584 posts
Posted 01 May 2013 - 10:18 PM
A quick check on excess crankcase pressure is simply to remove the oil filler cap with the engine running and put your hand over the hole to form a seal. There will be some pulsation, but you should feel a slight suction. That will apply to most cars, not just Minis. If there is pressure instead of suction, clean out all the breathers thoroughly before suspecting a worn engine, if it is running ok and not burning lots of oil.
Always do the cheap things first, before trying the expensive. Cleaning the breathers and maybe renewing some of the hoses, if they are dodgy, is cheap and fairly quick compared to an engine rebuild.
