4 Spots On Spi Mini
Best Answer Dan , 02 May 2013 - 01:01 PM
  Wow I wrote that a long time ago!
  30 amp cable and relays with a 20 amp continuous rated fuse would be fine really, but personally I'd use a higher rated relay because they tend to be a little optimistic about their rating and fail quickly if they run at more than half capacity for an extended duration.  It might be better to keep them as 2 individually fused pairs (inside and outside) driven of the same relay.
  There is a law that might come into play here if you use this many main beam lamps, and I don't doubt people will argue with it because everyone thinks that main beam lamps are free.  This very rarely comes up because people don't usually have loads of lamps.  While it is true that there is no UK law stating the maximum number of main beam lamps, or the maximum power of the bulbs in them, there is a law that limits the total forward light intensity on main beam.  If you look at the lenses and find the E marking, you should find some other information with it.  A halogen driving lamp will have HR stamped in it somewhere, and maybe PL for plastic lens.  It will also have a number, all lamps with a main beam setting have a number which is usually 2 digits.  This is a code for the maximum forward beam intensity of that lamp when fitted with the bulb it used in testing.  All the numbers on all the main beam lamps you have may not add up to more than 75 total.  If you have fitted higher intensity bulbs then the number for the lamp will be wrong.  There is a specific figure in terms of candle power that must not be exceeded but it's easier to use the codes than to test the lamps.  A higher number doesn't mean the lamp is better, or brighter even, it just means it has a higher peak intensity somewhere in the beam.  So it might just be that the lens is very poor and all the light is focussed in one place.
Go to the full post
12 replies to this topic
#1 SlamDunc
SlamDunc
  • 41 posts
  • Local Club: Hilltop Minis
Posted 01 May 2013 - 01:52 PM
Hi Folks,
This may have already been answered somewhere but I can't find it.
I want to fit 4 spot lamps to my 95 SPI which already has wiring for two spots as per standard.
Is it safe for me to use the existing wiring to run the full set of 4 or do I need a seperate fuse/relay etc?
Edited by SlamDunc, 01 May 2013 - 01:53 PM.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 May 2013 - 03:22 PM
  You will need additional wiring.  If the car has the fog loom you could use that if you just re-arranged the switching of the relay.
#3 Cooperman
  • 23,320 posts
Posted 01 May 2013 - 04:24 PM
As Dan says you need an additional spotlight circuit which must include a new relay, 2 fuses, a switch and all new cabling.
#4 SlamDunc
SlamDunc
  • 41 posts
Posted 01 May 2013 - 06:39 PM
Brilliant! Cheers fellas. I'll check out the fog loom option - I'm presuming my car has one or get another wiring kit. Thanks for the advice
#5 SlamDunc
SlamDunc
  • 41 posts
Posted 01 May 2013 - 08:41 PM
Ok, I'm back now.
You'll need some parts. A couple of relays and bases, a couple of fuse holders, some ring eye fittings, at least one switch, wire and other stuff that'll be mentioned as I go along. You need to decide how you want your lamps switched. Neither set is permitted to be on all the time. The spot lamps must be wired so that it is not possible to have them illuminated while the headlamps are dipped. The conventional way to do this is to use a relay to control them, but you may decide you also want a switch in line so that you can turn them off independantly of the dip switch. While this is not required, it is a good idea. The fog lamps must be switched so that you can turn them on and off as required. I like to do this by using a second main lighting switch (with the front swapped for the one with the foglamp logo), setup so that in the sidelight position the rear fogs only are on and in the headlamp position both the front and rear fogs are illuminated. If you do this you will need to fit a warning lamp onto the dash to tell you when the front fogs are on as required by law. If you used a seperate additional fog lamp switch the lamp in that would be used as the tell tale so a seperate lamp would not be required.
You must take a new feed to supply both of these sets of lamps, the easiest place to get this is at the main battery terminal of the starter solenoid and for this you will need the ring terminals. I think you need 8mm ones to fit the stud. Run a cable from here to a position where you can mount some relay bases and fuse holders, probably the inner wing.
Connect the feed (or feeds) to a pair of fuses (one for each set of lamps). The fuse for each pair will need to be rated at 10 amps continuous. If you use glass cartridge fuses these will be labelled as 25 amp, if you use blade fuses they will be red 10 amp ones. This is simply because the two types are labelled in different ways, there is little difference between the two.
Each fuse should now connect to the load side of one relay (terminal labelled as 30). The other load terminal (terminal 87) of each relay should now be connected to the pair of lamps it is switching. The bulbholders of each lamp need to be connected in parallel, normally these lights use H1 style lamps which have a trailing blade connector for the supply. Using enough wire between them to get the lamps where you want them connect both of these together and connect to the relay base.
Now for the switching sides of the relays. Terminal 86 on each relay must be earthed to the shell. Terminal 85 of each relay must be wired to wherever you will mount your switches. This means getting inside the passenger cabin. Always run wires through the bulkhead by using grommets to protect them, preferably use an existing wiring grommet. These wires can be fairly small as they will be carrying very low current due to the use of relays. This helps with getting them inside the car. Take a feed from the sidelight circuit and connect to one side of the new foglamp switch, connect the other side to the wire from the foglamp relay making sue you also connect to the telltale lamp. The other side of the telltale will need earthing.
As for the spotlamps, wire the switch in the same way but the feed for the switch must be taken from the main beam circuit. A telltale is not requird for these lamps. If you choose not to have a switch for your spotlamps, the switching side of the relay can be connected to the main beam lighting circuit in the engine bay rather than running wires back into the cabin. There is an unused position in the bullet connector behind the slam panel which is ideal for this supply.
All the wiring you use everywhere must be capable of carrying at least the current rating of the fuses you use for this. This means 10 amp cable minimum for the load side of each circuit and the lamp earths. If you choose to use a single wire to supply the pair of fuses at the start of the circuit then it must be rated to at least 20 amps. The switch wires and the relay earths can be lighter gauge cable as I said above if you prefer but I wouldn't use less than 1mm cable myself which will probably be labelled as 8 amps.
That's about it. I'll be back later with a diagram.
Ok, I'm back now.
Hi Dan,
I just saw your original wiring post.
As I want to wire in 4 lights, could I not use a 60 amp relay, 30 amp cable & 20 amp blade fuse or equivalent?
I'm not keen on wiring in two lots of cables & relays if I don't need to & have just found that the previous owner has chopped the wiring back to the loom so my original plan of using the OE wiring for two lamps & adding a new loom for the others is scuppered.
Edited by SlamDunc, 01 May 2013 - 08:43 PM.
#6 Cooperman
  • 23,320 posts
Posted 01 May 2013 - 08:48 PM
You need to be able to use the spot lights as additional driving lights to supplement the main beam, whilst the fog lights are used with dipped beam in conditions of reduced visibility like fog or falling snow. You never need all 4 additional lights on at the same time as the range of the fog lights is less than the range of the headlight main beams so they are of no use at all in normal driving.
I always believe the best lights are Cibie Oscar or Super Oscar driving lights, just one pair, used as additional main beam headlights.
#7 SlamDunc
SlamDunc
  • 41 posts
Posted 01 May 2013 - 08:56 PM
These are just 4 driving lamps from Huddersfield Spares rather than driving & fog lamps if you get my meaning?
http://www.minispare...d=44&prod_id=11
I just want them to come on via the main beam rather than an additional switch & originally planned to use the OE wiring & an additional loom but now will have to use either an uprated loom (DIY)or two separate bought ones. Just trying to work out which is my best option?
Edited by SlamDunc, 01 May 2013 - 08:58 PM.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 May 2013 - 10:08 PM
Just make a new loom if your ok with wiring if not buy one pre made, but there not difficult to make to be honest.
#9 Cooperman
  • 23,320 posts
Posted 01 May 2013 - 10:52 PM
If you intend to run with all 4 lights, plus headlights on at the same time you might need an up-rated alternator. 4 x 55 watt bulbs = 220 watts = 18 amps. Add that to the other electrical units and see what you end up with. The headlights add an additional 110 watts = 10 amps, the heater fan adds 20 watts, the side & rear lights & no.plate lights add 30 watts, instrument panel lights add about 20 watts, ignition takes about 12 watts.
Now that's a rough total of 412 watts which is 35 amps. Always allow for 20% additional alternator power and you end up with needing a 50 amp alternator. That is without a heated rear or front screen.
With my 2 off Cibie driving lights with 100 watt bulbs I have a 70 amp alternator.
#10 SlamDunc
SlamDunc
  • 41 posts
Posted 02 May 2013 - 09:19 AM
Fortunately, the previous owner had upgraded the alternator so all good there.
What amp components, relay, fuses, wire etc should I be using to make my own wiring kit for all 4 lights?
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 May 2013 - 01:01 PM   Best Answer
#12 SlamDunc
SlamDunc
  • 41 posts
Posted 02 May 2013 - 01:24 PM
That's great, thank you. I'll get shopping for 30 amp cable & I think I saw a 60 amp relay with diode on t'internet which should do the job nicely. Single 20 amp blade fuse holder & a party pack of 30 amp fitting & connectors it is then!
Thanks for all your help gents and I'll post some piccys once done (assuming I don't electrocute myself in the process!)
#13 SlamDunc
SlamDunc
  • 41 posts
Posted 02 May 2013 - 07:01 PM
Or alternatively.....
http://www.autospark...roducts_id=1887
This ticks all the boxes & is cheaper than me buying all the components!
