Accuspark Rev Limiter
39 replies to this topic
#1 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 02 May 2013 - 03:43 PM
Seeing as I couldn't find any videos of Accusparks limiter, thought I'd make one of my own. Only got the limiter a couple of days ago, very very easy to install and use, and it hasn't broken yet!  :P Set it to about 6000rpm for now, but I really bought the limiter so that I can turn it down and not over-rev the freshly rebuilt 1275 that's going in, that admittedly has yet to exist, but hopefully will be created in the coming months...
Enjoy.
The Otter
Edited by The Otter, 02 May 2013 - 03:50 PM.
#2 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 02 May 2013 - 03:56 PM
How easy are they to fit? is there instructions? :P
#3 The Otter
The Otter
  • 620 posts
Posted 02 May 2013 - 04:06 PM
There are instructions yes haha, it was literally the easiest electrical thing I've ever fitted to the car, there are three wires (all with pre-crimped ring terminals), one black, one white, one red. The black is an earth, so got screwed in to a hole in my inner wing, and the red and the white go on to the positive/negative terminals on the coil - that's it! Get a small spanner/socket on the nuts that hold the male spade terminals on to the coil power studs and undo the nuts, slip on the right ring connectors, then put the terminals back on and connect everything up again - easy peasy!
I fitted the box itself to the inner wing with just a single self-tapper, again in to a random hole that happened to already be there  :lol: Must have taken me all of about half an hour, and then you adjust the limit with a tiny screwdriver that's provided in the box. Needless to say I'm very impressed with it, especially seeing as it's only £30 - so much cheaper than the alternatives!
#4 Moggyton
Moggyton
  • 1,152 posts
Posted 02 May 2013 - 04:10 PM
Might be a good idea to run my new engine in with then!
Edited by Moggyton, 02 May 2013 - 04:10 PM.
#5 rally515
rally515
  • 3,848 posts
Posted 02 May 2013 - 04:47 PM
How compatable is this unit ?  i.e. can i use it on a rover v8 haha.
Sounds as though it would be as coils are the same but thought id ask to be sure as its software might go "Fizz fizz, bang bang" knowing my luck :goaway:
#6 The Otter
The Otter
  • 620 posts
Posted 02 May 2013 - 04:55 PM
http://www.ebay.co.u...=item27ca4057a3
Quote:
This is a Genuine AccuSpark Rev Limiter
Works with all cars that have a single coil triggered by a points or electronic distributor
NOT SUITABLE FOR LATE CARS WITH COILPACKS AND ECU'S
This is an essential piece of kit to Protect your Classics Engine
Soft Cut Rev can be set from;
 2000 - 12000 RPM on 4 Cylinder Cars
3000 - 8000 RPM on 6 Cylinder Cars
4000-6000 on 8 Cylinder Cars
#7 The Otter
The Otter
  • 620 posts
Posted 02 May 2013 - 04:57 PM
So as long as it has a single coil, apparently you can  ;D
#8 rally515
rally515
  • 3,848 posts
Posted 02 May 2013 - 04:58 PM
Ahh damn, its running injection & an ECU :lol: .
:goaway:
#9 jimmyH
jimmyH
  • 260 posts
Posted 02 May 2013 - 05:01 PM
No go for an MPI then ... ?
#10 The Otter
The Otter
  • 620 posts
Posted 02 May 2013 - 07:04 PM
As I quoted four posts ago...
Nope  :rolleyes:
#11 jimmyH
jimmyH
  • 260 posts
Posted 04 May 2013 - 06:59 PM
Shame...
#12 iwatkins
iwatkins
  • 381 posts
Posted 04 May 2013 - 08:06 PM
Neat job, and wow, cheap too. :-)
Used to use a similar but much more expensive one on my Celica back in the day. Using a momentary push button by the gear stick, holding it down engaged the rev limiter at 4600rpm, letting it go turned the limiter off.
So on the Celica which was turbo'ed and 4 wheel drive, this gave a basic launch control. Means you could go full throttle on the line and build to about 7psi of boost (full boost was around 22psi). Dump the clutch then let go of the button as you reached for second gear. Stopped it bogging down off the line. Worked really well and gave you about 3/4 - 1 second over the quarter mile. Used to use it at Santa Pod a lot.
The side effect was when sat on the line and limiter engaged, it made an almighty racket of bangs, pops and flames, very anti-lag like. Usually scared the other competitor out of the win. :-)
Video of another owner doing the same below.
Ian
#13 robminibcy
robminibcy
  • 1,516 posts
Posted 06 May 2013 - 12:13 AM
does the accuspark systen have a second setting that can be used as a kind of launch control? I've been looking at these for no other reason than to make pops and bangs!
#14 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 06 May 2013 - 08:12 AM
If all you want is pops and bangs, I have a dodgy condensor you can have for nowt. Pops and bangs like a bad un every time you put your foot down.
#15 The Otter
The Otter
  • 620 posts
Posted 06 May 2013 - 03:15 PM
Don't expect too much, the Accuspark one is cheap for a reason  :lol: If you want launch control as well, then that's part of where the extra money goes in something like this Omex one:
http://www.ebay.co.u...=item51ac66bc94
Pretty sure Hegnirst has one like that in his clubby.
Edited by The Otter, 06 May 2013 - 03:17 PM.
