Accuspark Rev Limiter
#16
Posted 06 May 2013 - 03:30 PM
#17
Posted 06 May 2013 - 04:55 PM
But, if you want a rev limiter *and* a launch control you would need two, or something like an Omex unit.
With a soft cut limiter, you also have the ability to full throttle gear change.
#18
Posted 06 May 2013 - 05:14 PM
From what you're saying, you'd need one to limit the revs at max RPM (say at 6K), and one to be working as your limiter when you wanted to use launch control (say at 3k - not sure what you'd want to use to limit spin etc)?
Am thinking if people would want to use just the one to limit the revs when they push the switch, then as soon as they've got away release the switch (and therefore they wouldn't have a top limiter)...? Or wouldn't that work?
I've played with the launch control on an Omex before (a friend has it on his MK4 Fiesta (running jenveys, shawspeed cams and what not) but just wanted to know for my own reference.
#19
Posted 06 May 2013 - 07:23 PM
That would work fine. It is exactly how old school launch control works and what we used to use for drag strip usage.
Not sure how well it would work on a Mini, but worth a try. Might be good fun for the traffic light Grand Prix.
Ian
#20
Posted 06 May 2013 - 09:35 PM
Ian
I like your thinking! Would be quite fun, esp the other drivers faces as you're popping next to them at the lights... That combined with a shift light...hmmmmmm.
#21
Posted 12 May 2013 - 08:23 AM
What a lovely and tidy little unit, very impressed. If you open it up, all the internals are totally covered in potting compound so it should be fairly weatherproof too.
Just need to set ours to about 6200rpm but was a bit late last night to do that on the driveway.
Fitted mainly to stop anyone buzzing the engine.
Ian
#22
Posted 12 May 2013 - 09:52 AM
noobie question, but what is ''launch controll''? I assumed it was to hold your revs, but obviously you could only do this with fuel injection...
also the accuspark kit is described as 'soft cut', has anybody actually got any McPoppin'? ![]()
#23
Posted 12 May 2013 - 11:14 AM
For a Mini, I would use it to allow full throttle on the line giving power off the line and to restrict wheel spin.
The Accuspark is soft cut, so as a rev limiter rather than a launch control, it's very gentle which at say 6200rpm is what you want. We've just been out setting ours up and got it about right. Once the engine was hot we were getting the occasional bang and pop on the limiter. Nice but not stupid. I would expect once we get a LCB and bigger exhaust on there it'll be more noticeable.
I'm going to get another unit, make it switchable, I.e. off/on then also try it to control it from a switch on the clutch. I.e. with it switched on, clutch in, you can go full throttle. Will try around 4000rpm as a limit. As the clutch comes up, it'll switch the unit off so you can get all the revs. up to the actual rev limiter. So in theory, you can go full throttle off the line without wheel spin. Also as you change gear, you can keep your throttle buried and do full throttle gear changes.
I've used this exact system on an Alfa in the past for sprints/climbs and with a lot of fiddling especially the clutch switch, you can get great results. But it takes a lot of tweaking to balance the limit set for launch against the limit used for full throttle changes. In all cases with launch control and full throttle changes, your drivetrain and clutch *will* suffer additional strain.
Ian
#24
Posted 20 September 2013 - 04:53 PM
How's the limiter going? I'm thinking in getting one soon and was just wondering if it lasted?
#25
Posted 20 September 2013 - 09:41 PM
#27
Posted 21 September 2013 - 10:39 AM
#28
Posted 21 September 2013 - 06:13 PM
But I see your point. Still, saves the engine a bit.
#29
Posted 21 September 2013 - 06:56 PM
Well to be honest I can't be 100% helpful here as the Mini has been laid up in the garage since August 1st! It was working fine up until then though, still doing as it should and at the same RPM setting I put it on back in May, so it's lasted me at least 3 and a half months without any issues ![]()
#30
Posted 02 March 2014 - 07:10 PM
Is the limiter still working ? ![]()
