Hi all. I have recently got my mini on the road after 3 years of fixing it up with a very good friend of mine. We noticed that the clutch master cylinder was leaking so I replaced this. I had previously replaced the slave cylinder and also replaced the pipe for a braided hose. Any way we bled the system so that there's no air in, but I still have no clutch. The pedal is very soft and I was wondering if I need to adjust the clutch? I've read that I have to wind the bolt in but I'm not really getting the whole process! Is it just a case of winding the bolt right in and then out so that it's 5mm off the arm? Will this stiffen up my pedal? Any tips would be greatly appreciated. Thanks, Kev.
Clutch Problem
Elks2012
, May 06 2013 08:24 PM
1 reply to this topic
