Posted 14 May 2013 - 09:35 PM
Fit the rubber into the screen apperture first, use a squirty bottle with a strong washing up liquid and water mix and spray around the rubber giving it a good soaking.
Drop the screen into the bottom of the rubber, then using a suitable tool (I use a plastic wedge) work your way around the edges of the screen folding the rubber over the edge of the screen, really try to avoid the temptation to use screwdrivers to do this.
Fitting screens gets easier the more you do, so be prepared to struggle a little if this is your first.
You will need the correct tool to fit the chrome finishing strip, available from minispares quite cheaply, again, lots of water and washing up liquid will ease insertion.
Good luck :)
