New Powerspark Ignition
17 replies to this topic
#1 venkman
venkman
  • 454 posts
Posted 12 May 2013 - 06:28 PM
Hello,
Not to sure this is the right place to post but thought i would put a few pictures up of the distributor.
Just fitted to 998cc designer mini.
After we fitted it and re-set the timing i wish i had done it earlier its like a different car!!!
Its very straight forward and did plug and play (after some choice words didnt realise the drive on the end of distributor are slightly offset).
http://i1320.photobu...zpsdd7c7ee6.jpg
http://i1320.photobu...zpsecdfe51d.jpg
http://i1320.photobu...zpsdd14710d.jpg
http://i1320.photobu...zpsf31227b9.jpg
http://i1320.photobu...zps48c20d3c.jpg
http://i1320.photobu...zps8569a8ec.jpg
#2 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 12 May 2013 - 06:37 PM
i always advise people to switch to electronic iginition, it just saves fidling switching points etc.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 12 May 2013 - 06:38 PM
Can't see all the wiring but how have you wired the new dizzy..
It looks like you have the red wire going to coil positive...but the coil positive all shows the white/yellow wire.
Have you kept the ballast coil ??? If so the dizzy red wire needs a new 12v feed not connected to the coil
#4 venkman
venkman
  • 454 posts
Posted 12 May 2013 - 06:42 PM
The red wire is connected to the positive of the coil and yes its still a ballast coil. Does it need a feed direct from the fuse or somewhere closer?
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 12 May 2013 - 06:44 PM
yes the red wire needs a feed off the fuse box...use the white wire...white wires are unfused 12v ignition switched live.
rest of the wiring is fine its just the red wire needs a new feed and do not connect it to the coil
#6 venkman
venkman
  • 454 posts
Posted 12 May 2013 - 06:49 PM
Can i trace one back up the loom, just on the inside of inner wing and make a join or better to run a new wire from the fuse box.
Why does it run ok and what would happen if not changed?
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 12 May 2013 - 06:59 PM
Shouldn't be any white wires in the loom running to the front...closest will be up round the fuse box.
Probably just lucky its running OK but not seen one of these yet that doesn't recommend a full 12v feed, and at the moment it'll be running around 9v
Just read through the FAQ's on Powersparks page and it mentions removing the ballast or switching to non ballast coils.
So seems definitely it wants a 12v feed
#8 venkman
venkman
  • 454 posts
Posted 12 May 2013 - 07:04 PM
Right off outside now while its still light and will get it sorted, put a picture up tomorrow.
Twice you've bailed me out in past and now pointer in the right direction, you sure know your electrics! :highfive:
#9 lrostoke
lrostoke
  • 6,923 posts
Posted 12 May 2013 - 07:08 PM
just remember its only that red wire needs a new connection, it becomes a separate connection from the coil.
Coil wiring stays standard
#10 venkman
venkman
  • 454 posts
One last thing if people were interested
www.simonbbc.com  Helpful and best £77.00 spent!
#11 venkman
venkman
  • 454 posts
Posted 12 May 2013 - 07:09 PM
Got that Thanks
#12 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 13 May 2013 - 10:36 AM
I'll second that. Simon is very obliging.
#13 venkman
venkman
  • 454 posts
Posted 13 May 2013 - 04:08 PM
http://i1320.photobu...zps1e402542.jpg
Carn't really tell but red wire removed from coil and joins a black wire (my own wire!)
http://i1320.photobu...zps3bf3a669.jpg
Then cable tied following loom
http://i1320.photobu...zpsc3497820.jpg
Then you can just see the wire above the green/white
Started up still goes!!!! :proud:
#14 venkman
venkman
  • 454 posts
Posted 13 May 2013 - 04:25 PM
received an e-mail from simon, he has asked me to post this link regards the coil.
 http://www.simonbbc....aq-page/#link22
#15 retroracer1275
retroracer1275
  • 543 posts
Posted 13 May 2013 - 04:33 PM
my electronic ignition lasted around 5 mins, now have no spark etc
