There's A Sack Of Spanners Inside My Engine!
18 replies to this topic
#16 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 20 May 2013 - 10:46 AM
it could cause the timing chain to jump wrecking pstons etc, meaning you will need a rebuild
#17 retroracer1275
retroracer1275
  • 543 posts
Posted 20 May 2013 - 11:44 AM
i drove mine like a nut for a month with it making that noise (excuse to do an engine rebuild) and it did no harm, just made an awful noise
best to get it sorted asap though incase anything goes wrong
#18 psychobob
psychobob
  • 205 posts
Posted 20 May 2013 - 02:21 PM
its worth looking at the tensioner. my original 998 sounded exactly the same, although I have to admit, I left it for 6 months before investigating. it turned out to be half the nylon tensioner bouncing around inside the cam chain cover. its lucky really that it didn't knock a hole through the casing.if you do swap it, make sure you don't over tighten the bolt that locks the tensioner in place. it screws into the aluminium backplate and will thread really easily. a huge nightmare will ensue!
#19 BVY
BVY
  • 639 posts
Posted 20 May 2013 - 10:41 PM
Ok.
I replaced the alternator and re-adjusted the tappets. Now it sounds like a mini again  :D
Hope you get it sorted Rob!!!
