2K Or Celly ?
18 replies to this topic
#16 FlyingScot
FlyingScot
  • 2,675 posts
Posted 24 May 2013 - 02:57 PM
What he said ^^^^
Since the people posting the advice about just wear a mask it will be okay obviously haven't read the thread that Smackfiend posted above...
Here is an extract posted by Malcolm the admin on the MIGwelding forum after speaking to 3M one of the most respected manufacturers of "masks" he points to this info
Paint spraying
Hazard Inhalation of isocyanates found in 2-pack paints
Advisory PPE Supplied air breathing apparatus
Suggested Product Supplied Air Visor System (3M Visionair)
6000 Series Full Face Mask with 06971 Supplied Air System
7500 Series Half Face Mask with 06971 Supplied Air System (must be worn with eye protection e.g. goggles as shown)
Premium Line Goggles (2790A) Acetate lens
Unsuitable PPE Particulate respirator (e.g 6922)
Gas and vapour respirator (e.g. 6941)
Mask with filters (e.g 6000 Series Full Face with cartridge filters)
That's right 3M the people who make probably some of the best kit around say their own Gas and Vapour Respirator ISN'T suitable..
The phrase a little knowledge is a dangerous thing springs to mind
FS
Edited by FlyingScot, 24 May 2013 - 02:58 PM.
#17 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 19 June 2013 - 07:38 PM
What he said ^^^^
Paint spraying
FS
With this information folks think very very carefully about what you wear.
Now although there is not a warning on the forum page for this section please heed the advise given in the Problem, Questions and Technical section, and i quote
Problems, Questions and Technical
This section can be used to get help with any technical problems which you are experiencing with your Mini. You can also help others with their Mini related technical issues.
Warning
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action. Not only is this annoying, but it can also be costly and could even bedangerous if the wrong information is given. This is why we ask that only first-hand and factual information is posted in reply to peoples queries. If you are not 100% certain of your reply, be sure to point out your uncertainty.
#18 Dusky
Dusky
  • 5,322 posts
Posted 18 December 2015 - 04:02 PM
Have you considered the 2k non iso paint, think the hardener basically turns 2k paint into 1k acrylic. I have used it with 2k primer with results better than cellulose high build. I have some clear to try it with but not got round to it yet.
You could even use water based and top with a 1k acrylic clear.
did you ever get round trying it on a clear coat?
#19 Daz1968
Daz1968
  • 2,058 posts
Posted 18 December 2015 - 05:15 PM
I wasn't happy with it at all and bought an airfed mask to use proper 2k products. On primer I like high build epoxy as it doesn't absorb moisture, as for the clear I think the 1k acrylic from upol is better than the unibinder.
