Lowering
Posted 20 May 2013 - 08:03 PM
Posted 20 May 2013 - 08:08 PM
Would it not be easier just to get hilo's?
Posted 20 May 2013 - 08:12 PM
Was thinking of getting some but once fitted never adjusted again so thought this option better?
Posted 20 May 2013 - 08:13 PM
hi might be worth buying some hi/lo set saves chopping the rubbers.
Posted 20 May 2013 - 08:22 PM
Definately buy hilo's they are not expensive and well worth it.
Just a note from experience, once you start playing around with your suspension components. You'll probably end up needing to service your upper suspension arms and your knuckles are probably bonded to your trumpets beyond removal and same possible with your suspension donut and trumpet at the top end so if your gonna lower it just set aside a couple of hundred.
get two new donuts hi lo's new knuckles new bump stops to start. then prepare for possible replacing quite a few bits.. It is a mini expect the unexpected!
Edited by johnyc, 20 May 2013 - 08:24 PM.
Posted 20 May 2013 - 08:35 PM
From what I've heard it's quite difficult as it would have to be a perfect cut etc, and making sure they're at the same level... may just be worth a set of hi-lo's to be honest.
Posted 20 May 2013 - 08:43 PM
its on here somewhere, like a 5 to 1 in the front and 3 to one in the rear i think...
Posted 20 May 2013 - 08:44 PM
That would make sense - that's what it is for the hi-lo's.
Posted 20 May 2013 - 08:47 PM
Other way around.
Posted 20 May 2013 - 09:02 PM
Thanks everyone for your advise think i will get some Hi-Lows now.
Posted 20 May 2013 - 09:16 PM
Other way around.
Well...I was close :)
