Msa Questions
20 replies to this topic
#1 Awamckay
Awamckay
  • 165 posts
  • Local Club: The Faithful Few Mini Club
Posted 29 May 2013 - 10:12 AM
i'm looking at getting back into stage rallying (clubman level) and just have a few questions for those of you that have built rally cars recently.
i've built rally cars in the past and put webber boxes in and had removeable front ends, my question is;
with the new regulations of no modifications to either bulk-heads, can i still put a webber box in (as the worx cars did)??
if its a no, i have a problem as the shell i have got has already been cut for a box.
the other thing, can i still have a removable steel front if its securely bolted and brace bars?? i always used to compete with my front end like that.
thanx.
Drew.
#2 rally1380
rally1380
  • 1,893 posts
Posted 29 May 2013 - 10:34 AM
Can't see the Weber box being a problem but will need to check the Bluebook
I'm pretty sure removable fronts are not allowed...but i'm sure thats another one for the Bluebook.
Welcome to the TMF rally club Drew.
#3 keefr22
keefr22
  • 591 posts
Posted 29 May 2013 - 01:26 PM
The Weber box should be OK as I had a rally biased, Mini loving, MSA scrutineer going over ours last week & he didn't mention any problem with it!
In case you don't have one, the 2013 Blue Book is on line here;
http://msauk.org/sit...sp?article=1158
#4 Awamckay
Awamckay
  • 165 posts
Posted 29 May 2013 - 01:30 PM
thanx guys, looks like i have to buy/make some inner wings :( what a tit, lol
#5 Awamckay
Awamckay
  • 165 posts
Posted 29 May 2013 - 01:31 PM
what you recon about leaving the inner wings out, welding the rest on but still using brace bars?
#6 keefr22
keefr22
  • 591 posts
Posted 29 May 2013 - 01:55 PM
I really have no idea about the inner wings question. Tomc from here recently posted a similar question about whether flip fronts and associated mods were allowed in hillclimbing on the Uphill Racers forum. I'm almost as confused by the answers he got as I am when reading the Blue Book...!!
I'm now a bit concerned about the Weber box. I was sure the BB said it was permitted to modify the bulkhead for induction, but reading again it only states it may be modified to "accommodate the fitting of an alternative engine and/or gearbox and/or differential and/or axle, seats and exhaust" - I'm pretty sure if there were a problem the scrute I saw last week would have mentioned it, as he was certainly quick enough to point out a problem I have with the roll cage in my Ibiza! I'm hoping that the weber box is covered by "cars with modifications conforming to their homologation papers (46.2)" - but whether all homologation papers cover the Weber mod is another argument. It would seem ridiculous if they allow the bulkhead to be modified to fit a whole different engine, but not a different carb..But there seems to be a whole lot of stuff that's ridiculous in the regs these days...
Sorry, that really isn't that much help, is it?! I shall try & give the scrutineer a ring tomorrow.
#7 Awamckay
Awamckay
  • 165 posts
Posted 29 May 2013 - 02:01 PM
if you can please.
there's a few minis that compete at our local events (3sisters and newbrighton rally) that have removeable fronts, they are bolted so are solid, thats why i was asking, but they were all logbooked a few years ago so i dont know if its a change in the rules for newly built rally cars.
the BB is soooooooooo confusing at times, lol
#8 Awamckay
Awamckay
  • 165 posts
Posted 29 May 2013 - 03:05 PM
48.1.2.
All bodyshells, inclusive of removable panels
and parts must be of the vehicle manufacturers
specified materials, specifications and minimum
thickness with the exception of bonnet, front wings,
bumpers, hatchbacks, tailgates and boot lids which
may be of alternative materials. Seam welding, and
localised gussets/reinforcement is permitted.
i'm taking that as i can use fibreglass/carbon fibre wings so these can be bolt on ;) lol
#9 keefr22
keefr22
  • 591 posts
Posted 29 May 2013 - 04:28 PM
48.1.2.
I'd say yes, because it excludes front wings. Even though the manufacturers specification is weld on...!!  O_O
Good fun this Blue Book surfing, isn't it?!  :D
#10 Awamckay
Awamckay
  • 165 posts
Posted 29 May 2013 - 07:08 PM
just welded the front end on, can't be arsed with the hassle, lol
and
after a phone call to the tech department at the MSA i've email some pics and specifications for the weber box for their aproval.
#11 keefr22
keefr22
  • 591 posts
Posted 29 May 2013 - 07:21 PM
Strewth, you don't hang about...!!
Can you let us know what they say about the Weber box?
#12 Awamckay
Awamckay
  • 165 posts
Posted 30 May 2013 - 04:56 PM
Will do mate :)
#13 keefr22
keefr22
  • 591 posts
Posted 05 June 2013 - 09:55 PM
Did you get a response from the MSA about the weber box? I haven't been able to get hold of the scrute I know, but I know he'll be at the Epynt hillclimb next week, so if I don't speak to him before I'll ask him then.
#14 Awamckay
Awamckay
  • 165 posts
Posted 10 June 2013 - 02:14 PM
still waiting for a reply from them, just welded the bulkhead up instead, i'd still like to know for future refference tho.
#15 DEPS
DEPS
  • 188 posts
  • Local Club: Carlton & District Motor Club
Posted 11 June 2013 - 07:06 PM
Hi,
The following link takes you to the HRCR technical site for a cat 2 mini. This states you can use a weber carb, so that would indicate you must be able to add an air box. It also gives some other interesting options.
Another question though, can you use 4 pot brakes.
http://www.hrct.co.u...ategory-2-mini/
Like you say it is all a minefield and the changing regs do not help the clubman and his costs.
