Painting The Mini
47 replies to this topic
#31 black olive
black olive
  • 262 posts
Posted 09 July 2013 - 10:05 PM
epic 10 hour polydiscing sanding and painting session. both sides and bonnet back to bare metal and acid etch primed. NO MORE GREEN DUST !!
#32 minbin 69
minbin 69
  • 465 posts
Posted 09 July 2013 - 10:08 PM
looking good :thumbsup:
#33 Petrol
Petrol
  • 967 posts
Posted 09 July 2013 - 10:13 PM
Agreed, looking good. Where do you get your poly discs from? They look the dogs for stripping paint.
Pete
#34 black olive
black olive
  • 262 posts
Posted 11 July 2013 - 09:53 PM
Pete, any good engineering merchants should stock them.
roof painted today, guide coat applied and wet flatted, then 6 coats of OEW celly. it ws really too hot to paint, and is a bit lemon peely, but theres all but a litre on there so plenty to go at for flatting and compounding
#35 SAL 821X
SAL 821X
  • 1,890 posts
Posted 12 July 2013 - 07:43 AM
I can see the shine already!
In what direction did you spray the roof?
I know when doing the sides you go left to right horizontally or visa versa, but with the roof do you do from back to front or side to side.
haha if that makes sense!
#36 black olive
black olive
  • 262 posts
Posted 14 July 2013 - 09:50 PM
I went round the gutters with the spray pointing downwards, and just a nip on the paint flow screw, then upped the flow a bit and did round the outsides, then with more flow went front to back then back to front working towards the middle, then zipped round the the other side of the car and in the same fashion back to the side. it seriously ws too hot though really, it is a bit lemon peely, but ive made sure there is a good thickness for a flat and compound . hope this helps, not the easiest to put into words !
#37 SAL 821X
SAL 821X
  • 1,890 posts
Posted 15 July 2013 - 08:30 AM
Fantastic cheers fella.
Printed out and put in my "this is how you spray" folder for future reference.
#38 black olive
black olive
  • 262 posts
Posted 15 July 2013 - 08:56 PM
another 10 hours has seen the bonnet crossmember repaired, and both sides high build primered :))
Edited by black olive, 15 July 2013 - 08:57 PM.
#39 black olive
black olive
  • 262 posts
Posted 16 July 2013 - 09:30 PM
bonnet and bootlid wet flatted and the insides painted. didnt bother wet flatting the insides. was a bit hot again really but turned the air screw down a bit and used plenty thinners and got an acceptable result after 4 good coats
#40 black olive
black olive
  • 262 posts
Posted 20 July 2013 - 09:24 PM
after a few days, the roof is looking even better. depth of reflection before flatting compounding and polishing
#41 black olive
black olive
  • 262 posts
Posted 30 July 2013 - 08:50 PM
wooooohoooooo , wet flatted, allowed to bake in the sun, and tweed grey topcoated ( roof was done last week) plenty on to allow for wet flt and compound. after 10 months of grft, I did have a lump in my throat after I had demasked it. just got the bonnet and boot outers and doors to do, plus the door and boots hinges etc and its all ready for reassembly
#42 black olive
black olive
  • 262 posts
Posted 30 July 2013 - 08:51 PM
few more pics
#43 black olive
black olive
  • 262 posts
Posted 02 August 2013 - 09:08 PM
twin tanks trial installation
#44 black olive
black olive
  • 262 posts
Posted 11 August 2013 - 09:00 PM
bulkhead stripped stonechipped and first coat of tweed grey. loom checked cleaned and retaped. ive used black because I had a few rolls of loom tape left from a V6 anglia I wired up haha. Imgoing to relay the lights up to reduce volt drop ( and increase brightness) and reduce wear on the switch contacts. Ill be making these for sale shortly
#45 elmengue
elmengue
    Starting My Mini Up
  • 1 posts
Posted 15 August 2013 - 02:09 PM
Great work friend! 'll try to learn from you, A Wave
estupendo trabajo amigo! intentare aprender de usted, Un Saludo
Edited by elmengue, 15 August 2013 - 02:10 PM.
