I know it's not a breaker bar, that's why there are breaker bars... I had 2 torque wrenches so why buy a breaker bar when I could use one of the torque wrenches?
I'm going back there so I can record the conversation so I at least have some sort of proof that they are the ones who messed it up.
I have hilos fitted and the cones are old. Easy to do.
I have breakdown cover for a reason.
But thanks for talking to me like a child. Appreciated.
I'd think the reason why you'd not use a torque wrench as a breaker bar is because it will wreck it, no matter how many of them you have. That's really quite an odd philosophy - i have two of something, so it's OK to break one, but still, each to their own.
You can record what you want, you can't divulge it without their permission either that or openly record it, but then you may find the garage has a use for your other unwrecked torque wrench - well it won't get wrecked, more ...well rectum.
Do you think the garage will care much now you've opted to carry out your own repairs? If you tell them the story of you using a 6' bar on a 1/2" torque wrench, they might ask if you were even turning the bolts the right way. I'm puzzled too, if the job was easy - you could have done it all yourself and not now have to go back and try and reason with men who can do up a turret bolt so tight that close on 1000 ft lbs can't get it undone.
Hope the breakdown cover is of use, the last time I used the RAC, I think you got a squirt of WD40 and if that didn't work, a fast tow up the A5 on a short rope.
