Pot Joint Oil Seal Leak?
20 replies to this topic
#16 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 25 June 2013 - 10:18 PM
You might want to check to see how much play there is in the diff output shaft support bushes as excess play could be why the seal has failed. If there is excessive play you need new bushes which need to be machined to suit the inner end of the pot joint.
How do I check for play? Do I just try and wobble it? (Sorry very basic term used) What defines as excess play?
#17 Ethel
  • 26,004 posts
Posted 26 June 2013 - 12:46 AM
Yes, and wobble is as good a term as any. Any discernible movement is suspect, oil leaking past your new seals is a cert.
#18 IainStallard
IainStallard
  • 1,114 posts
Posted 26 June 2013 - 06:49 AM
Thanks! Will check tonight!
#19 IainStallard
IainStallard
  • 1,114 posts
Posted 26 June 2013 - 10:18 PM
All done tonight! Seal was incredibly hard from age, boy does the minispares tool make removing the pot joints much easier! Highly recommended and definitely worth the money!
#20 KOY1980
KOY1980
  • 16 posts
Posted 28 July 2013 - 12:50 PM
Hi
I'm just picking up on this one and a noobie so tell me to shut it if you like. The great advice I got on here for the C pin on the gear selector is penetrating oil (cup of tea) followed by a technical screwdriver rather than a crappy punch and medium hammer, came out easy! I used a spacer with the seal and now dry as a bone.
Next is the driveshaft seals. I'm waiting on a ball joint separator. Thought I would change the offset at the same time should I do both sides whilst the oil is out?
#21 IainStallard
IainStallard
  • 1,114 posts
Posted 28 July 2013 - 01:04 PM
May as well change both at the same time since its ballache to do with draining the oil each time
