Hot Running Problems - Any Ideas
19 replies to this topic
#16 adamg1380
adamg1380
  • 141 posts
Posted 11 June 2013 - 07:04 PM
Water wetter does help.
What about the water pump and it's pulley? There are different water pumps and things you can do to stop them churning up the water (one thing that water wetter does), see http://www.minispare...mps/GWP134.aspx
#17 lawrie124
lawrie124
  • 1,711 posts
Posted 12 June 2013 - 04:38 AM
definately run a heater matrix as a second radiator.
I've always run with the standard rad, and with a matrix plumbed in aswell I haven't had any problems for years. I kept the thermostat too, and made sure it was warm before the start of the race.
thanks Sam; sure I had a couple somewhere but can't find them so will try and get one off the banger boys
#18 lawrie124
lawrie124
  • 1,711 posts
Posted 12 June 2013 - 04:41 AM
many thanks; worth a punt. First step is to whip the head off tonight and look at the bores, to see if I have glazed or scored.
#19 jaydee
jaydee
  • 8,565 posts
Posted 06 July 2013 - 09:18 PM
If you get the whole assembly balanced (pistons and rod weight balanced + crank, fly and cluth, pully harmonically balanced) then engine will last longer at high revs
By the time you're at 6k rpm for most of the race i'd evaluate the option, a properly balanced engine will also make you gain something, every little helps in racing.
#20 lawrie124
lawrie124
  • 1,711 posts
Posted 08 July 2013 - 07:18 AM
thanks Jaydee. One of the bores was worn do binned that block and fitted a spare one, but that's knocking it's bits off at the bottom end so going to take my time and build a decent one.
cheers
