Hi all just a quick questin. My full beam keeps getting stuck on and
its becoming a pai for other road users. Just wonderin if it will be
the light stalk or a loose wire?
full beam
JA1987
, May 01 2006 03:48 PM
4 replies to this topic
Posted 01 May 2006 - 03:48 PM
Posted 01 May 2006 - 05:25 PM
I'd check the stalk first really. Not something I've ever had a problem with, but generally I start at the switch and work me way backwards if I can't guess easily.
Posted 01 May 2006 - 05:33 PM
probably the stalk. there's a metal "lever" contact in there that will probably be bent a bit too much. Alternatively, you may have a short somewhere, but that's harder to find.....
Posted 01 May 2006 - 05:58 PM
Cheers how do I check this? Do I just remove the stalk and check the
connection?
Posted 01 May 2006 - 06:12 PM
now you're making me think. I've told people about that
Remove the shroud, and I *think* you can see the contacts. I can't quite remember if you need the wheel off to get to it easily though.
