I have a friend with a pit in his garage. Would this make things easier, or shall I just use ramps and a few jacks? Actually it could be a good time to inspect the entire exhaust area.
I'll make a tick list of parts as I check and hit minispares on saturday.
CHECKLIST:
- Top Steady (remove rubber bushes. Buy new poly one piece bushes)
- Bottom Steady (replace bushes or buy one if steady isn't there)
- Downpipe/manifold clamp (remove clamp, clean old corroded sealer, buy new exhaust sealer + exhaust heat tape, refit clamp)
- Lower downpipe clamp + bracket (check if it is there. If not, buy new one and fit as photo above)
- Check exhaust hangers (buy new and replace if rusty and corroded)
- Oil change (buy extra can 20/50 and drip tray. Drain existing. Refill)
- Check spark plugs for dark matter and signs of running rich
- Check carb dashpot as per another forum ''On SU carbs, there's a small lifting pin at one side near the back of the dashpot, with a spring on it. If you push that up, it will eventually hit the carb piston, letting air in. If it's rich, the engine speed will pick up, if it's lean it will fade away. If it's set right it shouldn't change much at all''
NON-ESSENTIAL PARTS
- Rear quarter window seal (opening type)
QUESTIONS:
1) When I clean the downpipe clamp connection to the maniflow, is exhaust sealer and the clamp sufficient? I was thinking of sealing it, then using some heat tape over the top, and then the clamp, just to be extra tight.
2) Assuming I let the oil drain until it stops dripping, there will still be (according to sources) 1l or so of oil still swirling around parts. How much oil should I expect to be topping it up to? Obviously by checking the max/min levels and measuring how much came out and adding the same, or more But the dipstick barely did anything different when I topped it up before, so its hard to tell if I am flooding it or not.
3) With all that done, should I leave the car ticking over for a bit to settle the new oil, or actuall drive it continuously for half hour or so?
4) Can I expect the exhaust to stop running spluttery and rich right away? Or is this another ballgame where I need to next think about the carb and timing settings etc.
