went out in the car today just as it was changing gear it it made a noise
then no gears at all this gear box has been working great up to now
this is an auto
has anyone got any ideas
thanks
Posted 19 June 2013 - 08:52 PM
this is an auto
thanks
Posted 19 June 2013 - 09:07 PM
there no movement in forward or rev.........when was it last serviced...........and you will probibly need to ajust the cable just a flat at a time and mark with white paint before you do........also you can use engine flushing oil pop a bottle in and run engine for 20mins drain and refill with cheap oil and another bottle of flush oil repete and drain new oil filter and top up with 20/50 corma classic oil
Posted 19 June 2013 - 09:17 PM
thanks will try it
Posted 20 June 2013 - 10:59 AM
No...I strongly advise against a flushing oil just yet.....and no disrespect to the other poster - but I wouldn't change any cable settings just yet (assuming he means the cable from the quadrant to the gearbox).
The steps suggested are as follows:-
if no gears can be selected (forward or reverse)
1) Oil level
2) Pressure test (1/8" port on side of oil filter)
3) Remove and clean aux valve block
4) Check main oil pump and flow valve, supply and feed pipe seals and main oil strainer seals
5) Check low pressure valve
Fwd oil pressure is between 75-85 PSI
Rvs oil pressure is between 115-125 PSI
If you only lost forward gears:-
1)Check the fitting of forward clutch feed pipe
2)Check the forward clutch and/or shaft rings
Have you lost drive in manual and reverse?
Edited by Captain Mainwaring, 20 June 2013 - 11:04 AM.
