hey i have a 93 carb mini, where would i find the fuse for the hazards/indicators/interior light?
wheres this fuse
minidude03
, May 02 2006 05:19 PM
6 replies to this topic
Posted 02 May 2006 - 05:19 PM
Posted 02 May 2006 - 05:30 PM
if you look in the top left of the engine bay there is a small black box which holds about 4 fuese i think. This is where that fuse should be!
Posted 02 May 2006 - 06:06 PM
but which of the four is it
Posted 02 May 2006 - 06:13 PM
Do you have a haynes manual? Cant find mine at the moment... it says in there think it might be the second one down... if u suspect the fuse has blown, then check them all...
Posted 02 May 2006 - 08:46 PM
See for a question like this most people would of expected a very simple answer!!
And that simple answer is: Its not one of the fuses in the main 4 fuse block. Its an in-line 10 amp fuse. I believe its one of the ones tucked up underneath the scuttle behind the carb.
Posted 03 May 2006 - 06:27 PM
Or you could just get a meter and measure across all of them. If you find one blown, thatl be your kiddie. If not, check in the wiring diagrams of your haynes manual, if you follow it through it should say.
Posted 04 May 2006 - 05:12 PM
problem solved, thanks for ur help
