hi,i currently have a a-plus engine,flat top pistons and a leaded head. i also have a unleaded head sat in the garage and the question is can i just bolt it on or do i have to get the valve chambers machined??
Cheers brooky
leaded to unleaded
Brooky
, May 02 2006 06:02 PM
2 replies to this topic
Posted 02 May 2006 - 06:02 PM
Posted 02 May 2006 - 06:12 PM
hi
as long as the head, is of the same size engine, then you dont need to do anything else, just change them over, remembering to use a new head gasket, and other gaskets as well
Posted 02 May 2006 - 06:23 PM
Cheers cowboy,its off the same size engine,ive got a gasket set but it'll need some new valves,dont no if it needs skimming but ive got a surface grinder in my garage ,i might port and polish it,im not sure,i havent looked at it that closly so dont no what it needs. Thanks again
Brooky
Brooky
