does anyone know for certain whether a 93 mayfair 1275 carb manual has a dim dip relay with drc6520 stamped on it behind the tripple clocks or not?
also does the same car have an electric cooling fan?
the answer to these 2 questions would be greatly appreciated, thanks.
discodavor
obscure question
discodavor
, May 02 2006 06:17 PM
6 replies to this topic
Posted 02 May 2006 - 06:17 PM
Posted 02 May 2006 - 06:31 PM
the '92 1275 carb sprite I had for the engine had an elctric fan (if that helps...)
Posted 02 May 2006 - 07:55 PM
cool mate cheers, just need to find out about the relay now
Posted 03 May 2006 - 07:14 AM
On my 1988 Mini the dim dip relay was clipped to the bottom of the lower dash rail to the right of the steering column.
Posted 24 July 2009 - 09:19 PM
On 89 mini 998 I found it hanging below that rail resting on the heater air intake, but Haynes shows a picture of it within the box frame to the rear of the instrument twin cluster, just below the metal can which I assume is the resistor for the dim dipped beam.On my 1988 Mini the dim dip relay was clipped to the bottom of the lower dash rail to the right of the steering column.
hope this helps
Posted 24 July 2009 - 09:29 PM
Throw away the dim/dip gubbins -it was NEVER required - and is just a nuisance.
Posted 24 July 2009 - 09:30 PM
Throw away the dim/dip gubbins -it was NEVER required - and is just a nuisance. And - it ruins halogen bulbs - by running them too cold. Get RID of it!
