Hi all are coil springs like this http://www.minispare....aspx?pid=38134
worth it ?
Cheers Chris
Coil Springs ?
01smartc
, May 02 2006 08:40 PM
8 replies to this topic
Posted 02 May 2006 - 08:40 PM
Posted 03 May 2006 - 04:54 PM
BUMP
Posted 03 May 2006 - 04:55 PM
You're not being ignored mate, they're just pretty rare things. I can only remember hearing about 1 or 2 sets being fitted myself. If none of us have them fitted we can't really say how good they are.
Posted 03 May 2006 - 05:11 PM
NeilG is going to use them, but hasn't had them on a drivable mini yet.
Posted 03 May 2006 - 06:14 PM
ive got them but again not driven with them
Posted 03 May 2006 - 06:28 PM
Chris, The blue springs will be soft and really need sway bars. Red springs could even use a rear bar. Green are a little stiff for street. Those springs are made by John Koo at Sracer. Top quality. He built my car and put red springs on mine. I have an MK1 and I can't believe that green would be any good on the street in a light car. Although I drove one of his MK3's with Reds and they felt softer than mine due to it being a heavier car. Do make sure that you order the correct bump stops. That way you can lower the car all the way down with hi los and not worry about the spring unsettling if you get airborne.
Posted 03 May 2006 - 09:37 PM
i have only heard good things from them you must get the proper S racer springs , a few cheap copies out there .
i get mine from the USA bit cheaper than minispares.
and will do 10% disscount for tmf guys.
http://www.16vminish...products_id=102
Matt
Matt
Posted 03 May 2006 - 09:51 PM
Which ones?
I was considering these but was worried theyll fall out
Posted 04 May 2006 - 12:59 PM
Bump stops won't help stopping them from falling out. You need to make some holes in the locating ring in the subframe, and then zip tie the springs to the locating ring to prevent them from getting dislodged if you raise the car or if you jump up in the air But to be fair with a lowered car, even rubber donuts can still fall out this way.
