Ok the Hif 44s are not 1.5" they are 44mm or I 3/4" and if they are Hif44s then they will be to big for your engine spec
They have different needles as the HIf 38 uses a 0.90" Jet and the Hif44 uses a 0.100" jet so there no interchangable, Not sure there is much nee le data out there for the twin HIF44s though, I have nothing listed in my data but its been done before.
Looking at your engine spec it would be over carbed and if you have the standard head then you could even get away with HS2 1 1/4s which will be ok up to 75-80bhp, your restriction will be in the cars head if its still standard.
Depends what your plans are if you need to up the carbs to HS4s 1 1/2" at a later date, but twin HIF44s are definitely to big and even if you got it setup on a rolling road the bottom end power would suffer due to poor air speed through to big a carb.
Edited by KernowCooper, 25 June 2013 - 01:01 PM.
