Running in
Posted 03 May 2006 - 02:28 PM
give me your running in procedures for a newly built engine please
Posted 03 May 2006 - 02:58 PM
Some nice thin oil for the first few hundred miles at low revs below 4k if you can help it, drain it. Then put some 10w40 in for about a thousand, keeping the revs low still. Then after that drain the oil for some fresh good quality oil and gently raise the revs over another few hundred miles. 1500 miles would be nice.
Posted 03 May 2006 - 03:11 PM
by 10w40 do you mean semi synth? fully synth? mineral? I've never really been that keen on 10w40 since I made the mistake of trying to run the mpi cooper with fully synth 10w40 in it, it wasn't happy!! I pressume though that a mineral one will be ok?
I generally stick to duckhams 20w50.
Posted 03 May 2006 - 08:59 PM
Posted 03 May 2006 - 09:19 PM
I can't believe it though this is the first car forum i've ever been on that there isn't a massive war going on covereing all and any ideas for running in
Posted 03 May 2006 - 09:57 PM
and whats best to use in an engine thats always being floored?
Posted 03 May 2006 - 10:19 PM
and then some better quality stuff after that. AS for running in processes I would personally ring up a few well know engine builders and see what they suggest as there are lots of different theorys.
Oh and the larger the number the thicker it is:)
Edited by Flappyplasticbits, 03 May 2006 - 10:19 PM.
Posted 04 May 2006 - 05:52 AM
cheers guys, is it worth getting some running in oil from minispeed for the firt 500 or so miles?
I always wonder what people are going on about when they say get some cheap 20w50? as I though tduckhams was great stuff for minis and thats only £7.99 for 4.5L round the corner from me!
Posted 04 May 2006 - 07:27 AM
Start engine for first time and leave running 'til hot, checking for leaks etc;
Take car for a run round the block to check everything works;
Stick it on the rolling road;
Change the oil;
Then go race.
Posted 04 May 2006 - 07:28 AM
LOL!! You should of seen a previous thread on which is the best oil for general use in an A series engine! It was monolithic! So we're all just quietly concious of it now. Its basically agreed that if you have a liquid substance in your engine with a consistency more than half-set jelly, but less than butter, you'll be fine!Cheers, pretty much what I thought, (after trying to run the mpi on fully synth).
Posted 04 May 2006 - 09:47 AM
Posted 04 May 2006 - 10:30 AM
after u run it in stick castral gtx in!!! expensive but secong to none espicailly if ur engine is fresh and new!!
strange you say that as I know a lot of people who wouldn't use castrol in their lawn mower.
Posted 04 May 2006 - 11:00 AM
Posted 04 May 2006 - 12:02 PM
Posted 04 May 2006 - 12:51 PM
As for running in here's what I'd do. Let the engine warm up at fast idle (1500 rpm). Then drive it around for the first 500 miles mostly under 3k rpm (an occasional trip to 4 shouldn't do much harm but still). Then raise limit to 4.5-5k rpm for next 1000 miles.
Change oil after first 500 miles. You can use the cheapest oil you can find for the running in procedure from what I hear.
I know many people swear by giving it a lot of stick to let it run at all of its operating range, but most manufacturers actually tell you to keep it below 4k or whatever (depending on car) for first so many miles. Surely them beaureacratic warranty department people know how to make and engine last for 2 years
