Halogen Upgrade Confusion!
44 replies to this topic
#31 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 13 July 2013 - 12:43 PM
I bought this kit today..........http://www.moss-euro...343&SortOrder=1
I thought it would be a straightforward installation, but after reading everything on this thread, it seems to be a bit strange that the kit includes a 20A fuse in the 12v feed circuit. Surely this can't be right as some have said, if the fuse goes, you have no lights?
#32 Cooperman
  • 23,513 posts
Posted 13 July 2013 - 12:57 PM
Only use fuses if you have 4 relays, one for each main beam and one for each dip. Then you can use 4 fuses after the relays. Anything else is basically not fail-safe and lights need to be 'fail-safe'. With 4 relays you can also fuse the relay feeds from the solenoid main power so long as each fuse is for one main and one dip supply to the relays.
#33 A-Cell
A-Cell
  • 1,610 posts
Posted 13 July 2013 - 01:01 PM
The kit is inherently unsafe. Fusing the main feed is dangerous as you say. If you use this kit don't use the fuse link, make a direct connection to the starter solenoid.
#34 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 13 July 2013 - 01:16 PM
I've emailed Moss stating that I don't think it's right to be fused......I'll see what they have to say!
#35 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 July 2013 - 03:26 PM
Be interesting to see what they say with 1 fuse its a lights out job -Not Recommended !
#36 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 13 July 2013 - 03:29 PM
Watch this space!!!
#37 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 15 July 2013 - 08:16 AM
I received this reply from Moss this morning....
"There should be a fuse in the 12v feed, this is to protect the circuit,
if this fuse blows there may be a problem with part of the circuit and
this will enable you to test and rectify, if you didn't have a fuse in
the circuit and you were to have a direct short in the circuit, it would
burn through the whole wiring loom, at worst set the car on fire."
#38 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 July 2013 - 09:47 AM
  Reply asking them if they are satisfied with their liability, should a single fuse failure take out all the forward lighting on a car driving on a dark motorway at night causing a pileup.  Especially since they not only sell it but also give the advice above.  If their response is along the lines of 'if you fit it it's your problem' then I think you will know how much respect to give their advice.
#39 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 15 July 2013 - 09:55 AM
I'm on it!
#40 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 July 2013 - 11:02 AM
If they come back saying modern cars are fused on the headlights then you can explain that their wiring differs in that the left and right headlight circuits are fused but run independent of each other so you could not loose one fuse and end up with total headlight failure.
They will come back with something about 12v feeds being fused and liability I bet you
#41 Cooperman
  • 23,513 posts
Posted 15 July 2013 - 11:22 AM
It is truly amazing how little some suppliers who deem themselves to be experts really understand about 'safety-critical' systems.
With electrical systems a single failure, say a fuse, should not have the potential for causing a catastrophic event. Sudden main beam failure could have this result.
A fuse failure should never result in the loss of more than 50% of the headlight mode selected (e.g. main beam).
In the 70's some cars were wired so that the headlights only worked with the ignition on. Sounds fine? Well, I had a Mk.3 Cortina GT and the throttle spring was a single spring. One dark December night the throttle spring broke, so I switched off the ignition, pushed the clutch down and braked, only for all the headlights to go out - blooming wonderful! I kept switching on and off until I stopped safely. It was no surprise when construction & use regulations were changed.
There must be no situation where all the headlights can be lost.
#42 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 15 July 2013 - 11:39 AM
The reply........
"If you look at the wiring diagram for the mini you will find that the
lights and other circuits are fused anyway so if you had a blown fuse
your lights would go out regardless if you fitted this relay kit.
If you are in any doubt about the fitting of this relay kit then contact
a qualified auto electrician."
#43 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 July 2013 - 11:46 AM
  Then I'd tell them to look at the wiring diagram for a Mini and ask them which of the fuses is for the lights!  The normal headlights weren't fused at all, on any Mini, until they were fused separately left and right main and dip on late SPi and all MPi cars.  They don't know what they are talking about, feel free to ignore them.
#44 Cooperman
  • 23,513 posts
Posted 15 July 2013 - 11:50 AM
They don't know what they are talking about, feel free to contact Trading Standards or the Motor Agents Association ;D .
#45 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 July 2013 - 06:18 PM
I would email them back and put them straight and point out there error someone could be fitting the kit right now!
