Back to the same issue...
So, I had a mechanic take a look at the car...seems he is having the same issue and is thinking the primary gear is not moving far enough and said the primary gear needs to be removed and the thrust bearing replaced...here is what is happing:
Car starts with the clutch in, but when in netural it stalls...when putting it in gear and to take off, stalls again. Because of the cost of labor on removing the primary gear, I would have to do it myself...the primary gear does move with the c-washer removed...thanks everyone!
