Nissan Powered Mini
4 replies to this topic
#1 Frans g
Frans g
    Starting My Mini Up
  • 2 posts
Posted 12 July 2013 - 01:56 PM
I have been following engine  conversion posts for a long time, but lately there seem to be nothing on nissan conversions.
Here is my car when I bought it in 2011
Attached File  IMG00320-20110410-1358.jpg   83.34K   19 downloads
It took me a year to get enough courage to start the job.
Attached File  06052012039.jpg   67.2K   6 downloads
Attached File  11052012043.jpg   55.79K   5 downloads
Attached File  22042012024.jpg   64.19K   3 downloads
It took another year to get body sorted out and sub frame changed.        Attached File  10022013038.jpg   86.78K   37 downloads
Attached File  10022013036.jpg   83.53K   59 downloads
Attached File  10022013035.jpg   77.8K   80 downloads
I'm using the cg10de engine from a nissan micra with the bigger gearbox of late model micra. The camshafts is from cg13de, which give more lift and longer duration, flywheel is lightweight from Jun Racing Technology in Japan. Inlet manifold is made out of toyota 4fe and cg10de that's cut and joined. The 4-2-1 exhaust system is home made up to the flexible joint. Bending pipes is no joke, took 10 days.
#2 rids
rids
  • 670 posts
Posted 12 July 2013 - 02:01 PM
theres a few nissan conversions here
http://www.theminifo...orum/167-other/
including mine.  lots of reading material for you and lots of inspiration.
everybody has done them slightly different to one another
Edited by rids, 12 July 2013 - 02:01 PM.
#3 l_jonez
l_jonez
  • 1,453 posts
Posted 14 July 2013 - 08:35 AM
Looking good so far, I like your engine mounts. Any pics of how well the inlet manifold fits, I never got around to doing mine.
#4 Frans g
Frans g
    Starting My Mini Up
  • 2 posts
Posted 17 July 2013 - 09:02 AM
Sorry for the delay, I tried to take some pictures of the manifold. The throttle linkage is from Toyota (hole re punched). Cable is form Ford transit van (shortened). No bulkhead modifications. The air filter is k&n for turbo mini.
Attached File  20012013023.jpg   50.85K   18 downloads
Attached File  20012013024.jpg   66.65K   13 downloads
Attached File  20012013025.jpg   68.42K   14 downloads
Attached File  GEDC1206.JPG   94.49K   19 downloads
Attached File  GEDC1211.JPG   70.02K   8 downloads
Attached File  GEDC1213.JPG   73.69K   4 downloads
Attached File  GEDC1217.JPG   75.35K   14 downloads
#5 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 18 July 2013 - 10:15 AM
Your inlet manifold looks very similar to mine before I sent it to be welded up....it's a drawn out process at the moment as he made up some adapters.
I thought I'd cut my toyota manifold off too short, but really had little choice...
Good to see the Throttle position sensor fits ....just it looks like once I get my manifold back I'm going to check clearance before deciding which way to orientate the throttle body.
Might be worth trying to find a GA15 throttle body as it plugs straight in to the micra loom and has the same bolt pattern too, the butterfly is exactly the same diameter as the inlet on the toyota manifold 45mm? Also use the GA15 injectors too!
Anyway interested to see how this goes as it seems similar specs to mine!
    Facebook (1)
