Mitp?
275 replies to this topic
#181 Alex_B
Alex_B
  • 4,573 posts
Posted 05 August 2013 - 05:52 PM
I think I will be there, currently contemplating the 6 hour round trip as its quite a long way :P would only be doing the sunday however as I have zero camping things and a 3 hour trip home on a hangover isnt going to be fun!
Anyone going up sunday morning from Eastbourne/south east area?
#182 samsfern
samsfern
  • 5,243 posts
Posted 05 August 2013 - 06:04 PM
Im going up saturday from dover, kent, might be going round the bottom of the m25, not decided yet.
#183 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 05 August 2013 - 06:09 PM
be driving from sussex on saturday with the freakz picking up a bbq and frozen stuff tomorrow also crate of cans dont think they like glass there.... probably will need an umbrella too lol.
mmmmmm must remember coffee and a kettle
#184 silve1999
silve1999
  • 1,146 posts
Posted 05 August 2013 - 06:10 PM
not too sure of the route but im kinda hoping not to do too much on the 25 :P
#185 RawlinsGTR
RawlinsGTR
    Formally known as Dog
  • 1,046 posts
Posted 05 August 2013 - 07:14 PM
After trying to sort an electrical problem since Friday (I had scheduled to have solved the problem by the end of Friday), I've finally sorted it today (I think).
Before that, I found that my hubs binded on my discs, which I had to sort. Then I found that my calipers binded on my discs, which I had to sort.
Now, I've just found out that my brake master cylinder is blocked in one of the inlets/outlets, which means no fluid is going to the front brakes.
My MOT is on Wednesday.
Which I'm now considering to reschedule to Thursday.
Still left to do: Rebuild my master cylinder, fit it, bleed my braking system, fit a heat shield for my catalytic converter, seal some holes in my floor, fit my interior, refit my dashboard, fill the car with coolant, paint wheels, re-polish wheels, get tyres fitted, set caster, camber, and toe out, adjust headlights, drill holes for new grille and surround, fit grille, fit bumpers, mould and fit side body trim, and pass MOT.
Then I need to wash the piece of ****.
Bets on whether I turn up to MITP in a 2000 Fiat Punto or a Red&White turd start here :shades:
#186 samsfern
samsfern
  • 5,243 posts
Posted 05 August 2013 - 07:28 PM
My bets on the Ferrari In Affordable Trim :lol:
#187 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 05 August 2013 - 07:38 PM
My mpi passed its mot today so that's me.sorted!!
I had been eyeing up poo as the back up but there was no need in the end.
Good luck with yours dog.
#188 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 05 August 2013 - 08:25 PM
I think you might be right Sam.. I just finished sorting the master cylinder problem, and filled up with brake fluid anddddddddd
Major leak at the banjo bolt and banjo for the driver's side brake hose. Brake fluid EVERYWHERE. All dripping off the subframe, all onto the floor. Tried tightening the banjo bolt, did nothing.
So.
#189 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 05 August 2013 - 10:14 PM
So clean that damn brake fluid up before it wrecks your hard work!
#190 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 05 August 2013 - 10:16 PM
So.
Did you fit both copper washers?
Also if you've fitted braided hoses then they are handed, the one with the deeper thread goes on the drivers side.
#191 Mini-Mad-Craig
Posted 05 August 2013 - 10:20 PM
So.
They are braided. If this fixes it then you can come to our tent for private time on Saturday :gimme:
#192 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 05 August 2013 - 10:24 PM
So.
Don't forget to check the copper washers, there should be one either side of the brake union, ie between the hose and the unions and then one between the bolt head and the union.
#193 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 06 August 2013 - 09:31 AM
So.
Sean, you're gonna be getting it fast and hard Saturday night.
Life saver!
#194 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 06 August 2013 - 11:24 AM
So.
Life saver!
Oh Goody.........
#195 Matt29992
Matt29992
  • 162 posts
  • Local Club: Mini Wanderers/Charnwood Minis
Posted 06 August 2013 - 11:41 AM
Thanks Laaly, some cool person took it hanging out the back of a Festa  :proud:
