Clutch Arm Seizing
Posted 26 July 2013 - 06:52 PM
Posted 26 July 2013 - 07:07 PM
Is this by taking off the alloy clutch cover and cleaning both the bore and the steel shaft ? I would have thought it would not seize every 1000miles if it was done by stripping it down and cleaning/greasing?
Posted 26 July 2013 - 07:13 PM
Posted 26 July 2013 - 07:46 PM
Posted 26 July 2013 - 07:49 PM
Posted 26 July 2013 - 08:08 PM
Posted 26 July 2013 - 08:13 PM
Its 2 disimilar metals so its what happens without cleaning and greasing.
Posted 26 July 2013 - 09:26 PM
I have lubed it with wd, white grease, lithium grease, ccopper grease, engine oil, still seizes every 1000 miles or so. Any recommendations?
So you've used everything except the proper manufacturer recommended type of grease then? It should be Graphite grease, the easiest brand to find retail is Graphogen. Working all these different and probably completely incompatible greases into each other without cleaning it out is asking fro trouble.
